Edited by
Discussion_Admin
Hi, I´ve been having problems lately with my Revit Architecture and my CAD 2010. I had both programs installed in my windows partition (because i have a macbook) and they runned perfectly. But yesterday I installed Parallel Desktop in the Mac size and this made my life horrible. Since I installed this program I can´t open either Revit or Autocad because it sends me an error and they close or because they say I have to Activate the product. I activate them with the correct serial number, key code and activation code but it doesn´t work and everytime I open them again it ask me to activate them again.
I made this several times and Autodesk sent me e-mails telling me that the products have been activated but still I opened Revit or Autocad and they asked me to activate again until know that appears me that I have reached the activation times.
I´ve done everything, I uninstall both products and still this legend appears me, I tried to activate them online and I have the same problems.
Please please help me because I just started to do a proyect and know I can´t continue and this is driving me crazy because I´ve tried everythin.
Thank you very very much
My serial numbers are
Revit xxx-xxxxxxxx
Autocad xxx-xxxxxxxx
When you installed Parallels Desktop, did you install a new OS in the virtual image (using an OS DVD or ISO image) or did you create a virtual image using your existing Boot Camp partition?
I am experiencing the same problem with 3dsmax and Parallels. I am about to uninstall Parallels, but this does not seem to do the trick. I am in contact with parallels, having reached 2nd level support.
I assume my precedenting forummember installed parallels the same way I did: First install Win on a bootcamp partition, then install paralllels on mac partition using the win-bootcamp partition as source.
Does this help solving the problem? Would be thankful for another hint...
Kind regards from Berlin
Martin
I'm having a similar problem.
I initially installed Revit on Windows 7 in VMware Fusion 3.1, but there was a problem with the video card driver, so I installed Revit again on a boot camp partition and it worked fine (except I had to disable graphics acceleration). I opened a new virtual machine from boot camp (mistakenly) and since then, Revit tells me I have reached my activation limit. The activation code won't work, even after I uninstalled Revit from the virtual machines.
What should I do about this?
Thanks in advance,
Dan
