I had to install and uninstall Revit 2014 several times as I was changing PCs (Performance issue). After a certain number of using the same product key, the product refuses to accept the same key anymore. Any help on how I can get a new key to activate the product, which I deseprately need for a university project. Thanks in advance.
Solved by Jroper. Go to Solution.
Call 1 800 551 1490 with your serial number and ask Autodesk. If you explain the situation they will probably activate it for you.
