I'm trying to reinstall Autocad 2007 on my computer at work after the hard drive was reformatted to remove a virus. It installs okay but when I enter the Activation code it tells me ther is a problem with the code. I called Autodesk and got a new number and even went through the acitvation on the internet and got another number but get the same message with each. I've double checked my typing to make sure that I entered the number as listed, it won't let me paste it in. Can anyone help me?
Solved by jessica.t. Go to Solution.
Hi! I'm having troubles with license after applying update SP2 for Autocad 2007, can somebody help me, I will provide cd key and request code through private msgs, thank you!
Hi UrosO,
You're likely to get a quicker response from the activation team by filling out the form linked below.
http://usa.autodesk.com/adsk/servlet/pc/item?id=18424632&siteID=123112
Hi @babatundeabdulahi , welcome to the Autodesk Community!
For direct activation and licensing assistance, please contact our License Assistance team by clicking on this link and then following the prompts:
Select “Activation & Registration” or “License Management”
Select appropriate subtopics from the pull-down menus.
Select “I Still Need Help” if you need personal assistance.
You will be able to contact the License Assistance Team either via Chat or e-mail.
Thank you
can u please tell me actication code for Autocad 2007
with serial number 111-11111111
hussain from Baltistan
imtibalti04@gmail.com
Hi @imtibalti and welcome to the Autodesk Community!
The serial number you have provided is invalid, was not issued by Autodesk, and therefore cannot be activated. If you purchased this license I would suggest that you contact the reseller and initiate a refund. To purchase a valid license from Autodesk, please contact an authorized reseller in your area.
Apologies for any inconvenience. If you have any further questions or concerns please let us know. Thank you!
Hello Hussain,
Have you been able to retrieve a valid serial number for your AutoCAD 2007 (see previous post)? If so, please contact the Activation and Registration team directly to get help with the activation:
1. Visit http://knowledge.autodesk.com/contactus
2. Select “Activation & Registration” or “License Management”
3. Select appropriate subtopics from the pull-down menus
4. Select “I Still Need Help” if you need personal assistance
If you have any other questions or concerns please reply to this post. Thank you!
I had to re-install Autocad 2007 Land Desktop on a new hard drive. My old hard drive was too small (only 40GB) and a was getting critically close to tapping it out. After I re-installed it on my new hard drive and started the program, it gave me the option to activate it or to start using it. I of course, elected to just start using it. I have used it that way now for a couple of months. Suddenly, this morning, I open my Autocad as usual to start my daily work routine, and the screen that comes up only give me the option "to activate the product". Well, so I tried to active it (with the activation code I received from Autodesk) and to my surprise it tells me that it is invalid. How do I go about getting another or correct activation code? This is the only Autocad I use and I'm getting behind schedule rapidly. I thought that since this is Veteran's Day, and I am a retired veteran that I might get some help.
Thank you,
Hi @dooiedooie and welcome to the Autodesk Community!
For licensing assistance, please contact our Activation and Registration team directly:
There you'll be able to chat with a live agent or submit an email if all agents are busy. If you have any other questions in the meantime please let us know. Thanks!
Hi @faisal403 and welcome to the Autodesk Community!
To contact the licensing assistance team please see the Accepted Solution above. However, this team will only be able to assist you if you have an existing 2007 license as we no longer offer that version. Thanks!
I had a computer crash and need to reinstall AutoCad 2007. I have the serial number and product key, but because it was already registered by someone else in the company I am unable to activate it.
Welcome to the Community, @Anonymous!
Could you reply with what the error says? Or if you could attach a screenshot we could better understand what the root cause may be. Typically with these types of licenses you only need the serial number and product key so it's unusual that you would not be able to activate based on the registration.
Thanks!
