While you're at it, be sure to include the missing DirectX file - d3d9x_30.dll that I noted under a separate topic.
On my PC I apparently had the latest DirectX loaded because it installed and ran fine. However, every client (about 5) who has installed it so far is seeing the same problem. I guess they can separately install DirectX 9, but I would rather they just be able to use the AutoCAD deployment.
BTW, I did a search of the .dll files on the install DVD under the x86 folder and I got a total of 1058, which is the same count as I had in my deployment. Does anyone else get that same total (the d3d9x_30.dll file was not one of the 1058)?
JPM
