Installation & Licensing
New Member
0 Kudos
Post 1 of 5
Accepted Solution
ACCESS DENIED - Sketchbook Pro 2011
191 Views, 4 Replies
04-01-2014 12:28 PM
I got the installer from the pirate bay and registered with the key I bought from you. It's sad that I had to do this.
Thanks for the suggestion! Are you activated and good to go?
Product Support
115 Kudos
Post 2 of 5
Re: ACCESS DENIED - Sketchbook Pro 2011
04-01-2014 01:55 PM in reply to: Feracon
Get the latest version from here:
http://knowledge.autodesk.com/support/sketchbook-products#?ADSKProductLine=Sketchbook%20Products&ADS...
I will alert someone to check on your serial number via private IM.
David Lau
220 Kudos
Post 3 of 5
04-01-2014 03:17 PM in reply to: Feracon
Hi Veracon,
I just sent you a private message with your serial number information. If you download the current version from David's link above and use the licensing information I've provided and the error persists please let us know. And if you could attach a screenshot of the exact error (without showing any sensitive licensing information) that would be very helpful.
Thank you!
Jessica Thrasher
New Member
0 Kudos
Post 4 of 5
04-01-2014 04:29 PM in reply to: jessica.t
Thanks both of you for the replies. For your trouble shooting I'm using Windows 7 Pro, Windows Security Essentials, and Windows Firewall. Even though neither of those likely interfered with the Akamai Downloader I disabled them.
It's likely it was a problem on the side of the downloader software you guys are using to server your installers. I'd strongly suggest offering an optional HTTP download link instead of relying wholly on Akamai.
Good luck.
220 Kudos
Post 5 of 5
04-03-2014 09:32 AM in reply to: Feracon
Jessica Thrasher
Post to the Community
New Post
