I got the installer from the pirate bay and registered with the key I bought from you. It's sad that I had to do this.
Solved by jessica.t. Go to Solution.
Get the latest version from here:
I will alert someone to check on your serial number via private IM.
Hi Veracon,
I just sent you a private message with your serial number information. If you download the current version from David's link above and use the licensing information I've provided and the error persists please let us know. And if you could attach a screenshot of the exact error (without showing any sensitive licensing information) that would be very helpful.
Thank you!
i just downloaded my autodesk sketch pro 7. but then it wouldnt download... i attempted to use my autodesk account i made during the purchasing process... , but then the page said i didnt have an account under that address... im using a mac with el capitan
