I am trying to evaluate Autocad electrical with the trial. When I start it I get the error unable to open application error 142 message.
I have Autocad 2012 installed and it is using a network floating license. I am pretty sure it has soemthing to do with this but I am not seeing how to get the trial working along with keeping 2012 working as is.
Thank you
Solved by asburyj. Go to Solution.
Can you provide a screenshot or the full text of the error you are getting? Also, what operating system is this?
In some cases this can be cause by a corruption of your microsoft .net framework 4 (or 4.5) can you try repairing or uninstalling and re-installing .net framework?
It looks like there may also be a conflict with adobe acrobat 9. Take a look at the solutions in this thread
Thank you, I had to run the Autoruns executable to uncheck the two .dll files that were shown.
Nvinitx.dll and nvinit.dll
