Installation & Licensing
*Bergström, Thomas
Post 1 of 2
Acad2000 NLS upgrading the Novell Server
76 Views, 1 Replies
01-16-2001 03:21 PM
Do any one know after you has installed the Adlm - NLS version of Acad
2000 on a Novell server 4.11 and now if you then are doing an upgrade to
5.1 Novell server will that upgrade affect the previusly installed
software for the Adlm - license utility. And if thats the case then what
can I do? Thanks!
*milana, jerry
Post 2 of 2
Re: Acad2000 NLS upgrading the Novell Server
01-23-2001 06:19 AM in reply to: *Bergström, Thomas
Thomas,
You will probably have to reauthorize the AdLM once you have finished. This
is because the authorization is bound to various parameters of your server's
network identity of which some are probably going to change in the upgrade
process.
Another thing to be aware of when upgrading to Netware 5 is that AdLM is
supported on Netware servers exclusively using IPX protocol. AdLM will not
work on Netware servers running only the TCP/IP protocol and is not
supported on Netware servers running both protocols. While some customers
have been able to get AdLM to work in multiprotocol mode, others have found
it necessary to remove TCP/IP from the server to get it to work.
jerry milana,
Autodesk Product Support
"Thomas Bergström" wrote in message
news:3A65480C.3E731215@Citydata.se...
> can I do? Thanks!
