Installation & Licensing
Product Support
avto
Message 1 of 1 (1,861 Views)
ACAD MEP 2011 – Error: Unable to load profile file.
1861 Views, 0 Replies
12-10-2010 02:01 PM
The error, “Unable to load profile file. Some profile information saved in last session may not be restored”, may be resolved by initiating secondary installer for ACAD MEP 2011
To initiate AutoCAD MEP 2011 secondary installer, follow steps below:
1.Rename following folders.
Windows XP:
C:\Documents and Settings\your_user_name\Application Data\Autodesk\MEP 2011
C:\Documents and Settings\your_user_name\Local Settings\Application Data\Autodesk\MEP 2011
Windows Vista or 7
C:\Users\assist\AppData\Local\Autodesk\MEP 2011\enu\
C:\Users\assist\AppData\Roaming\Autodesk\MEP 2011\enu\
2.Open Registry: Start > Run > type regedit in the open dialog box and click OK.
3.Export (back up) following key as reg file: HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.1\ACAD-9006:409
4.Then delete the key, HKEY_CURRENT_USER\Software\Autodesk\AutoCAD\R18.1\ACAD-9006:409, in registry.
Start AutoCAD MEP 2011 and do not migrate custom settings.
Avto Chachava
Autodesk Product Support
