Installation & Licensing
New Member
JAYMAN59
Message 1 of 2 (79 Views)
ACAD LT 2007 LICIENCE
79 Views, 1 Replies
03-03-2014 10:26 AM
I had problems using, so I exported licience and remove application and re installed Acad LT now I can't get the licience to import back. I have the selection under acad lt 2007 but nothing happens when i click on it, nothing launches
*Expert Elite*
pendean
Message 2 of 2 (67 Views)
Re: ACAD LT 2007 LICIENCE
03-03-2014 11:38 AM in reply to: JAYMAN59
You probably should not have done that... .
Windows version?
Autodesk recommended uninstall/reinstall procedures are as follows
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
More complete .NET fix if you did not go through this procedure:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
