Installation & Licensing
ACAD C3D 2012 - Failed installation aborted, Result=5100
3 REPLIES 3
hinanaaa
23294 Views, 3 Replies
Hi everybody,
I'm trying to install C3D 2012, and at the beginning I had some trouble with result=1619 (the microsoft visual c++ thing) and i already solved that problem..
Now my leftover problem is that i get the error message result=5100 - it exactly says:
6    BK    BK-HP    === Setup started on BK-HP by BK ===
2012/12/8:16:41:06    BK    BK-HP    Launch
2012/12/8:16:41:32    BK    BK-HP    PageOpen    LaunchDialog
2012/12/8:16:42:45    BK    BK-HP    PageOpen    LicenseDialog
2012/12/8:16:45:05    BK    BK-HP    PageOpen    ProductInfoDialog
2012/12/8:16:45:37    BK    BK-HP    PageOpen    ProductSelectionDialog2
2012/12/8:16:45:54    BK    BK-HP    PageOpen    FullProgressDialog
2012/12/8:16:45:54    BK    BK-HP    Installing .NET Framework Runtime 4.0 Language Pack: C:\Autodesk\AutoCAD_Civil3D_2012_German_64bit\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40LP_Full_x86_x64_1031.exe /q
2012/12/8:16:46:02    BK    BK-HP    Install    .NET Framework Runtime 4.0 Language Pack    Failed    Installation aborted, Result=5100
2012/12/8:16:46:03    BK    BK-HP    PageOpen    InstallCompleteDialog
2012/12/8:16:57:45    BK    BK-HP    === Setup ended ===
Can you please help me!
thanks :smileyhappy:
3 REPLIES 3
hinanaaa
in reply to: hinanaaa
got it! 🙂
I removed all .NET Framework things and then installed them again.. I used .NET Framework-Cleanup-Tool and Microsoft .NET Framework 4 (Standalone Installer) and now my ACAD C3D runs 😉
I had the same problem with "Result=5100" and I used CCleaner http://www.piriform.com/ccleaner  for cleaning up the registry and Window's useless files. After this you should install Civil3D regulary. GL
Thank you!!!!!!!
Administrator Productivity
