I opened a drawing drawn in ACAD mechanical and on its launch ACAD ELec 2012 froze and any other attempts to open the program give an error stating that a component in autodesk has stopped working. Not even trying to open a drawing now, just trying to open ACAD. The ACAD splash screen stops at "Checking License" in the text box where it is flashing what it is doing while loading.
I have uninstalled it a couple times, moved to 2013 and even 2014 with the exact same results. I go in and uninstall add ins first, then go and delete the user profiles, the Autodesk folders in program folders and program data folder. I deleted the FLEXnet folder, cleared the TEMP folder, deleted the Autodesk folders in the registry, did a CCleaner on the registry, have my Norton 360 turned off. Reload the software and it gives the same error. This is the only software giving me any issues.
Running W7 32bit.
Windows Error
AUTODESK component has stopped working.
Problem signature:
Problem Event Name: APPCRASH
Application Name: LMU.exe
Application Version: 5.0.39.0
Application Timestamp: 4f0e45b7
Fault Module Name: nvdxgiwrap.dll
Fault Module Version: 8.17.12.6696
Fault Module Timestamp: 4d4a29ef
Exception Code: c0000005
Exception Offset: 0000282a
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1033
Additional Information 1: 5b66
Additional Information 2: 5b66409d39459ef9547b66a860436dfc
Additional Information 3: 774a
Additional Information 4: 774a175c4391d98ecca7f4974479be58
