I was installing the Building Design Suite Ultimate and the ACA failed to install. However, when I try to run the install for BDS again, it says that ACA is already installed. ACA also does not show up in the control panel under add/remove programs. How do I make the suite install allow me to reinstall ACA?
Solved by TravisNave. Go to Solution.
To Diagnose and Fix installation problems automatically, please see the new Microsoft tool for this here:
http://support.microsoft.com/mats/Program_Install_and_Uninstall
For more information on the Autodesk KB Support article concerning the clean uninstall of Autodesk products, see this link:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=2887771&linkID=9240617
If that works for you, try reinstalling again and see if it will go.
Good Luck!
FYI, Chris was able to install ACA successfully after following the suggestion in Travis' post above.
