Installation & Licensing
2731 Views, 2 Replies
ac1st17.dll
I have an error when trying to read autocad files.  It states that the ac1st17.dll file is missing.  How can I recover this file, so that reading is operable again?  Thank you.
2 REPLIES 2
TravisNave
Did you do a search on your PC for it?
Might start here:
http://usa.autodesk.com/adsk/servlet/u/gsearch/results?siteID=123112&catID=123155&id=2088334&qt=ac1s...
Autodesk Forums:
in reply to: TravisNave
The file cannot be found anywhere.  Auocad has been uninstalled and reinstalled, as well as uninstalling pieces before the master program.  I read something in another article...  Is it possible that the file can live in some of the locations that it can be found in, while being gone in others?  If so, can I copy and paste the ones that are there into where they need to be?
Administrator Productivity
