Installation & Licensing
AC Mechanical 2010 (standalone) English beside AC 2010 (network) German?
3 REPLIES 3
dezmo.dezmo
477 Views, 3 Replies
I’ve standalone licensed AutoCAD Mechanical 2010 installed on my corporate computer in English language. Can I install network licensed AutoCAD 2010 in German language, keeping existing one (AutoCAD Mechanical 2010 English) as it is?
The reason is that I’m temporary moved to Germany and need to use macros what is created for German version of AutoCAD and “of course” they are not working with my English AutoCAD… and want to keep open both version on seme time.
3 REPLIES 3
TravisNave
in reply to: dezmo.dezmo
You cannot install identical products side-by-side, but you can install Mechanical and Vanilla.  So long as they are different products or different suites, that should work for you.
Autodesk Forums:
dezmo.dezmo
in reply to: TravisNave
Thanks a lot! Will try it next week, if my beloved IT support give an installnation files.. and permits. I'll report back than.
gsboyd
Hi Travis,
  I have a similar issue with installing a student version, and would like to use an english version or portuguese version of regular autocad.  Could I do one in Autocad, and one in AutocadLT?
Administrator Productivity
