Installation & Licensing
AC 2011 PL running problem
4 REPLIES 4
przemPL
478 Views, 4 Replies
Hello.
At the first I would like to apologize for my English, which is not good enough to communicate smoothly.
Today, I downloaded, from Autodesk official page, polish version of AutoCad 2011. I had no problems with instaled it. But when I try to run it, there is something strange. I double clicked on it, autocad starting, the first page of it is opening (gray background with red logo of autocad on left upper corner). But after few seconds, the program turns off. I tried run it with "run as administator" option, but it dosnt work. I have no idea what I have to do.
AutoCad is instaled on Vista.
Thanks for all posts.
przemPL
4 REPLIES 4
Darin.Green
in reply to: przemPL
Here's a couple of things to try:
1. Browse to and delete the file "Cascadeinfo.cas" from C:\ProgramData\Autodesk\ADLM. Once it's deleted, start the application again to see if it fully loads.
2. If the above doesn't resolve the issue, right-click the desktop shortcut and choose properties. Navigate to the Compatibility tab and check the box "Run this program in compatibility mode for" and choose Windows XP or a different vista setup listed.
Let me know if this works...
If this information was helpful, please consider using the Accept Solution
przemPL
in reply to: Darin.Green
thanks for quickly answer
i tried both ways you recomended, but they didnt work.
Is it possible that the problem is caused by the fact that I had on the same machine installed earlier version of autocad? (autocad 2005).
I tried to install autocad 2012 PL version, and everything was ok. but I need 2011 PL version 🙂
do You have any other ideas?
thanks a lot one more time for your post
and I am waiting for anothers
przemPL
Darin.Green
PrzemPL,
Its not good to install a previous version after a newer version was installed. First, try adjusting the virtual memory on your machine, using the process below. If this doesn't work, I think you should perform a clean uninstall of all autodesk products and reinstall them in chronological order starting with ACAD 2005 through 2012.
Clean Uninstall procedures
Check your virtual memory to make sure it's above the recommended size. For example, If the Recommended size is 4000, change the Initial Size to 4000 and set the Maximum size to 6000.
To access the virtual memory location, do the following:
Right-click My Computer, choose Properties
System Properties Dialog will open
Go to the Advanced tab and click Settings under Performance
Performance Options dialog will open
Go to the Advanced tab, and click the Change button located at the bottom of the dialog
Keep me posted.
przemPL
Problem is solved!
I installed patch 1.1 and now everything is OK 🙂
Thanks for help
przemPL
Administrator Productivity
