Installation & Licensing
*Martin, Jason
Post 1 of 3
A2K Network Installation to Netware 4.11 server
161 Views, 2 Replies
10-27-1999 08:47 PM
Most of this is something of a cross post from the adt 2 newsgroup, sorry to
those of you that read both.
Here's what I want to do:
I'd need to do a network install of adt2 to a Netware 4.11 server. In the
netsetup I set to network location to \\servername\volume\foldername
I'd need to use an NT server as a license server for adt. License manager
is already setup and running on the NT server.
On the license manager setup I'm selecting Install License manager later.
If I select IPX support I can't see the license server.
If I select TCP/IP support adt will kindof launch but no arx anywhere will
load. If I try to load any arx I get "AcRxDynamicLinker failed to load
\\servername\volume\foldername\arxname.arx'
\\servername\volume\foldername\acad.exeRegenerating model."
If I install to an NT server then adt seems to run. The only problem is I
must install adt to the nw server.
If the installation path is the netware server, the network deployment setup
will not work. When I click on the setup.exe I get an alert box that says
"Could not find files required to install AutoCAD. Contact your network
administrator or CAD manager for assitance.
I compared the NT network installation and the Netware network installation.
I found that the only files that were different were the following:
acad2000.cfg
deisl1.isu
desktop.arg
\plot styles\add-a-plot styel table wizard.lnk
\plotters\add-a-plotter wizard.lnk
\support\acad.mnc
\support\aecarchx.dll
\support\aecarchx.mnc
\support\aecarchx.mns
Most of these aren't a problem but the aecarchx.dll concerned me a little.
I don't have any C background so debugging the dll is beyond me but looking
at the dll in quick veiw reveals the following differences:
Novell Server NT Server
Checksum:00000000 Chekcsum:0003ac75
Nothing VA-Bound Import:0298
Nothing Size-Bound Import:0044
Even worse I just found this
http://www.autodesk.com/support/solutions/34763.htm . My initial read of
this leads me to believe that Autodesk has dropped support of installation
to anything but an NT server???
If anyone has gotten a2k, or actually adt2 to work in a network install on
an netware server please let me know what simple steps I've been missing.
TIA
jason martin
frankfurt-short-bruza
*Milana, Jerry
Post 2 of 3
Re: A2K Network Installation to Netware 4.11 server
10-28-1999 07:04 PM in reply to: *Martin, Jason
Jason,
It sounds like you may not have long file name support installed on your netware
server.
Jerry Milana,
Autodesk Product Support
> acad2000.cfg
> deisl1.isu
> desktop.arg
> \support\acad.mnc
> TIA
> jason martin
*Martin, Jason
Post 3 of 3
Re:
10-28-1999 07:36 PM in reply to: *Martin, Jason
Long file names are enabled on the server. We're running R14 and S8 from
the same vol. on the nw server, which also requires long file names. Any
other ideas???
jason martin
Jerry Milana wrote in message <38190096.87C38B77@autodesk.com>...
>Jason,
netware
>server.
>Jerry Milana,
