Hi there,
I am recieving the following error when opening Inventor 2011:
Licensing Error
A valid license could not be obtained by the network license manager.
If you are still unable to access a license, contact your systems adminisitation.
Error [0.0.0]
Below is the Log for ADLM when the application loads (C:\Documents and Settings\All Users\Application Data\Autodesk\AdLM\INVPRO2011ENUAdLM.log)
4088 2010/07/02 14:33:25 Reason=Fatal error
4088 2010/07/02 14:33:25 ComputerName=VBCWXPSEQ03
4088 2010/07/02 14:33:25 OS=5.1.2600.Service Pack 3
4088 2010/07/02 14:33:25 File=AdlmIntNWFBLicense.cpp,Line=684
4088 2010/07/02 14:33:25 VendorID=3 [FLEXLM-NW]
4088 2010/07/02 14:33:25 VendorError=-18 [Server does not support this feature]
4088 2010/07/02 14:33:25 FLEXLM-NW=v11.7.0.1 build 79971 i86_n3
4088 2010/07/02 14:33:25 File=AdlmIntNWFBLicense.cpp,Line=667
4088 2010/07/02 14:33:25 AdlmIntError=20 [License check out failed]
4088 2010/07/02 14:33:26 Reason=Fatal error
4088 2010/07/02 14:33:26 ComputerName=VBCWXPSEQ03
4088 2010/07/02 14:33:26 OS=5.1.2600.Service Pack 3
4088 2010/07/02 14:33:26 File=AdlmIntNWFBLicense.cpp,Line=684
4088 2010/07/02 14:33:26 VendorID=3 [FLEXLM-NW]
4088 2010/07/02 14:33:26 VendorError=-18 [Server does not support this feature]
4088 2010/07/02 14:33:26 FLEXLM-NW=v11.7.0.1 build 79971 i86_n3
Other details:
I created a deployment using the supplied tool for the installation.
Our client's use Windows XP Professional with SP3 and meet all the required software and hardware requirements.
I have updated LMTOOLS to version 11.7 and the license file has been updated.
The time on all of our clients is correct and synced with the license server (I seen this in another post as a fix).
I have re-downloading the Inventor 2011 installation files and tried recreating the deployment with less components.
I have tried performing a manual install and also installing the deployment on several different machines.
All required ports are open.
Other deployments work fine and the software is running from 1 license server (Inventor 2010, Inventor 2009. AutoCAD 2011, 2010, 2009, 2007. Revit 2011, 2010. MAYA 2010. SOFTIMAGE 2010. 3DSTUDIO MAX 2010. VIZ 2008. and a few others).
Please help,
Wayne
Solved by TravisNave. Go to Solution.
What note from Autodesk or whomever are you even talking about?
Are you talking about recent email replies you are getting since you participated in this discussion? If so none of these latest replies are direct toward you..
Mark Lancaster
& Autodesk Services MarketPlace Provider
You didn't.. But you participated in this discussion a while back which means you still subscribe to it. When someone replies or adds to the discussion all forum users who still subscribe to this posting will get an email regarding the update. If you don't want to be messaged again, unsubscribe to it.
Mark Lancaster
ping has work
all access done but network license not access
Post your debug log file. It will help determine your 0.0.0 error. Generally it is due to the wrong adskflex.exe version, mismatch in date/time/timezone, or the wrong product being installed at the client causing a license mismatch.
Hello @sepls,
Welcome.
Just to add. You posted a -15.570 Licensing Error that you receive on the Client computer.
We will need some more information:
Do other client computers pull/get a license?
Is there an options file in place that could be restricting?
Can you bind your license file to a port and try to restart the service (Bind to port 27005 and retry)?
You can try the following to test connectivity to the server from the client computer:
Let us know if you need some more suggestions & please be sure to provide us with this information. Thank you.
Please "Accept As Solution" if a reply has helped resolve the issue or answered your question, to help others in the community.
Natasha
Community Product Support Specialist
Helpful Links:
AutoCAD Videos | AutoCAD Crashes or Freezes | AutoCAD Customer Council | AutoCAD System Requirements | Prepare your computer for download | Autodesk Virtual Agent | Clean Uninstall | Steps for Setting-Up Student Software
