Installation & Licensing
A software problem has caused Autodesk Installer to close unexpectedly.
40 REPLIES 40
Message 1 of 41
19304 Views, 40 Replies
I am trying to install Autodesk Infrastructure Design Suite Premium 2014, and I receive the same error each time I try to install: " A software problem has caused Autodesk Installer to close unexpectedly."  I have tried installing from downloaded files and from the USB thumbdrive with the files, and the error is the same each time. I have all programs, including the virus scan, disabled or closed.  I have uninstalled AutoCad Civil 3D 2014.  None of these efforts have been succesful.  It goes no where and is locked on the intiallizing screen.  I have to use task manager to shut the whole installation down.  This was not an issue when I recently installed Civil 3D 2014 on the same computer.
the screen shot is included.  Does anyone else have a similar problem and/or know of a solution?
40 REPLIES 40
Message 2 of 41
Darin.Green
Log in as a different user with Administrator permissions and see if you're able to open the application without these errors.
If this information was helpful, please consider using the Accept Solution
Message 3 of 41
mclaborn
I have had the same problem. Have you found a solution yet?
Message 4 of 41
Darin.Green
in reply to: mclaborn
Make sure your Antivirus software is disabled.
Message 5 of 41
mclaborn
in reply to: Darin.Green
This is what ended up working for me: Uninstall 'Displaylink Core Software'. Worked just fine after that.
Message 6 of 41
dmac2525
awesome. this worked for me.
Message 7 of 41
adeban
Dear Sir ,
Hello , i need help please , how to uninstall the Displaylink Core Software ? ,as you mention to solve  my problem same your problem .
thank you
Message 8 of 41
mclaborn
Should be the same as uninstalling any other program:
Start > Control Panel > Programs and Features > Search for 'Displaylink Core Software' > Uninstall
Message 9 of 41
adeban
Thanks for Reply ,
i make the same steps for uninstall Displaylink Core Software but i not find this program in my program ,how i can find this program or either name for this software ?
Message 10 of 41
Darin.Green
in reply to: adeban
You may not have DCS installed if you couldn't find it in your uninstall programs list. Have you tried turning off you Antivirus application before installing?
Message 11 of 41
adeban
I disable Antivirus ,but after same problem A software problem has caused Autodesk Installer to close unexpectedly
Message 12 of 41
Darin.Green
in reply to: adeban
By any chance, are you using a Dell Precision laptop?
Message 13 of 41
adeban
i used HP laptop windows 8 64 bit
Message 14 of 41
Darin.Green
in reply to: adeban
Can you post the logs files from your temp directory? to get to this location, hit the windows key then type %temp% and hit enter. Sort the files by date modified and post the logs pertaining to the Autodesk installation.
Message 15 of 41
Thank you !!!
This worked great for me
Message 16 of 41
tugrulsevik
I tried to install Autocad 2015 (student version), and I received a warning "A software problem has caused Autodesk Installer to close unexpectedly."
I tried all advices. However, I received same warning when I tried to install Autocad 2014.
Message 17 of 41
Darin.Green
in reply to: tugrulsevik
Disable User Account Control (UAC). To do this, click start and type "uac" in the search box, then hit enter. Slide the bar all the way down to the bottom, save, close, and reboot your machine.
Then try starting the application again.
Sent from my T-Mobile 4G LTE Device
[cid:image547db8.GIF@47a50d02.4d8503e1]
Darin Green
Synergis Engineering Design Solutions
Lead Product Support Specialist
472 California Road | Quakertown, PA 18951
Main Office: 800-836-5440
Direct Dial: 215-302-3000
Fax: 215-302-3001
www.synergis.com
Blog | Facebook | Twitter | LinkedIn | YouTube
[cid:imageaebaee.JPG@4985f35b.4981952d]
This email and any attachments are intended only for the person or entity to which it is addressed and may contain information which is confidential, privileged or otherwise protected from disclosure. Distribution or copying of this email or the information contained herein by anyone other than the intended recipient is prohibited. If you have received this email in error, please immediately notify the sender by return email and please delete and destroy this email and any attachments.
Message 18 of 41
tugrulsevik
I disabled UAC and restarted my PC. Also, I've deactivated my antivirus. However, same warning was occured again.
I added the screenshot of warning, again.
Message 19 of 41
Darin.Green
Check to see if you have .net framework 4.5.1 installed. If so, uninstall it and install 4.5 from the Autodesk installation files.
Darin Green
[cid:imagebce5dc.GIF@2edf5564.47b46904]
Darin Green
Fax: 215-302-3001
www.synergis.com
[cid:image31fac6.JPG@7aeaa1c9.43bf61e9]
Message 20 of 41
tugrulsevik
I uninstalled 4.5.1 version of .net framework, but I could not find 4.5 version in Autocad Installation Files. I downloaded from Microsoft website, and will setup it. I guess that there is no problem, is that? Also, do I need restart PC after setup of .net framework?
Administrator Productivity
