Installation & Licensing
New Member
jegodwinjr
Message 1 of 24 (4,095 Views)
A software problem has caused Autodesk Installer to close unexpectedly.
4095 Views, 23 Replies
06-23-2013 06:08 PM
I am trying to install Autodesk Infrastructure Design Suite Premium 2014, and I receive the same error each time I try to install: " A software problem has caused Autodesk Installer to close unexpectedly."  I have tried installing from downloaded files and from the USB thumbdrive with the files, and the error is the same each time. I have all programs, including the virus scan, disabled or closed.  I have uninstalled AutoCad Civil 3D 2014.  None of these efforts have been succesful.  It goes no where and is locked on the intiallizing screen.  I have to use task manager to shut the whole installation down.  This was not an issue when I recently installed Civil 3D 2014 on the same computer.
the screen shot is included.  Does anyone else have a similar problem and/or know of a solution?
Darin.Green
Message 2 of 24 (4,082 Views)
Re: A software problem has caused Autodesk Installer to close unexpectedly.
06-24-2013 08:35 AM in reply to: jegodwinjr
Log in as a different user with Administrator permissions and see if you're able to open the application without these errors.
Darin Green
Synergis Technologies
If this resolve your issue/question, give Kudos or Accept as Solution...
Member
mclaborn
Message 3 of 24 (3,067 Views)
11-15-2013 01:46 PM in reply to: jegodwinjr
I have had the same problem. Have you found a solution yet?
Darin.Green
Message 4 of 24 (3,021 Views)
11-18-2013 05:21 AM in reply to: mclaborn
Make sure your Antivirus software is disabled.
Darin Green
Member
mclaborn
Message 5 of 24 (3,010 Views)
11-18-2013 07:51 AM in reply to: Darin.Green
This is what ended up working for me: Uninstall 'Displaylink Core Software'. Worked just fine after that.
New Member
dmac2525
Message 6 of 24 (2,962 Views)
11-19-2013 08:02 AM in reply to: mclaborn
awesome. this worked for me.
Member
adeban
Message 7 of 24 (2,651 Views)
12-17-2013 04:01 AM in reply to: jegodwinjr
Dear Sir ,
Hello , i need help please , how to uninstall the Displaylink Core Software ? ,as you mention to solve  my problem same your problem .
thank you
Member
mclaborn
Message 8 of 24 (2,641 Views)
12-17-2013 06:05 AM in reply to: jegodwinjr
Should be the same as uninstalling any other program:
Start > Control Panel > Programs and Features > Search for 'Displaylink Core Software' > Uninstall
Member
adeban
Message 9 of 24 (2,627 Views)
12-17-2013 08:38 PM in reply to: mclaborn
Thanks for Reply ,
i make the same steps for uninstall Displaylink Core Software but i not find this program in my program ,how i can find this program or either name for this software ?
Darin.Green
Message 10 of 24 (2,608 Views)
12-18-2013 06:34 AM in reply to: adeban
You may not have DCS installed if you couldn't find it in your uninstall programs list. Have you tried turning off you Antivirus application before installing?
Darin Green
