I have to install few clients and I becomme the same Error.
The clients are win7 64 bit with AutoCad 64bit, The licence server is a Linux machine installed through our Linux service in the USA. The Client and the Server are in different subdomains.
I have added the aditional DNS suffx in the client network adapter so he can find the linux server.
If I ping the linux server by the name i become a reply through the IPv4 adress.
I have unchecked the IPv6 protokol in the network adapter, i have modificated the registry settings in HKEY_LOCAL_MACHINE\SYSTEM\CurrentControlSet\Servic es\Tcpip6\Parameters\ like it is described in the post http://forums.autodesk.com/t5/AutoCAD-2011/64bit-licensing-error-15-570-0/td-p/2693521 , I have stopped the Ip Helper Windows service.
I have set a system variable
LM_LICENSE_FILE = 1800@bguslslan01:2080@bguslslan01:1717@bguslslan01 :1900@bguslslan01
Nothing helps, I still get the Error.
Has someone a idea what I can do?
Here are informations that I have become by the Linux Services about the Licencing Server:
License server status: 2080@bguslslan01
License file(s) on bguslslan01: /var/flexlm/license/bgladsk:
bguslslan01: license server UP (MASTER) v10.8
Vendor daemon status (on bguslslan01):
adskflex: UP v11.7
Feature usage info:
Users of 64300ACD_F: (Total of 1 license issued; Total of 0 licenses in use)
Users of PLIST: (Total of 1 license issued; Total of 0 licenses in use)
Users of 85536ACD_2011_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 71200ACD_2010_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 57600ACD_2009_0F: (Total of 1 license issued; Total of 0 licenses in use)
Users of 54600ACD_2008_0F: (Total of 1 license issued; Total of 0 licenses in use)
I noticed that your NLM is still version 10.8. You might consider also upgrading it to the latest version as well. You might make a system environment variable called ADSKFLEX_LICENSE_FILE and put the value of @bguslslan01. You may also need to ensure that bguslslan01is pointed to the correct IPv4 address in your hosts file as a final way to override the IPv6 settings. -15 error essentially means that a connection cannot be make to the NLM, so make sure all the ports are open that the NLM uses: 2080, 27000~27001.
in our case we should put in the servername with the portnumber like portnumber@servername
with the variables it does not worked.
Your ADSKFLEX_LICENSE_FILE shouldn't need the port since the Autodesk vendor only uses 2080. Do you have other vendors serving licenses in your NLM?
