Installation & Licensing
64-bit installer
17 REPLIES 17
Message 1 of 18
kevin.a.fox
62933 Views, 17 Replies
64-bit installer
I need the 64-bit installer for AutoCAD LT 2013 as I recently upgraded from WindowsXP to Windows7.
17 REPLIES 17
Message 2 of 18
pendean
in reply to: kevin.a.fox
If you are just looking for a product download you should be able to find it at the Autodesk Customer Service Virtual Agent:
1. Go to http://www.autodesk.com
2. Click on Contact Us at the bottom of the page
3. Click on Customer Service
4. Click on Virtual Agent “Ask”
5. Once the Virtual Agent window opens: Select the choice "Download Links".
6. Select your product, then variant, then version as applicable.
7. You should now be presented with the choice to download your software.
Message 3 of 18
kevin.a.fox
That did it, thanks!
Message 4 of 18
in reply to: pendean
Please let me know how to installed the 64-bit installer.
I could not find out the download way.
Message 5 of 18
philip.s
Hi Ray!
To download supported current and previous version software from the Autodesk Virtual Agent (also linked in our How to download or re-download software solution), simply click on the Download Links option and select your product.
Here to help if additional clarification is needed, otherwise please accept as a solution so that others can benefit from this information.
Message 6 of 18
in reply to: philip.s
how to get a serial key?
Message 7 of 18
philip.s
Hello @Anonymous and welcome to the Autodesk Community!
Can you please provide some additional info so that I can troubleshoot accordingly. Are you a student? Did you purchase a license and are unable to recover it? Let me know!
Message 8 of 18
I cannot find a 64bit installer program to install Autocad Electrical 2015.
Message 9 of 18
philip.s
Welcome to the community @Anonymous!
Did you try downloading from the previously mentioned Autodesk Virtual Agent (also linked in our How to download or re-download software solution) by simply clicking on the Download Links option and select your product?
Message 10 of 18
Message 11 of 18
I want to install Autodesk DWG Trueview 2015 to convert my drawings to 2010 and it doesn't want to installed.
there is a message tells me that i'm using a 32-bit installer on a 64-bit OS.
how to solve it ?
Message 12 of 18
Where can I find the Virtual Agent "Ask"? I can find it after I clicked the Customer Service.
Message 13 of 18
camilo.lemos
Hi @Anonymous ,
You can find the Virtual Agent on this link.
I hope this helps!
Camilo Lemos
Message 14 of 18
why does it says error9...installation is aborted.
Message 15 of 18
HI ,     ive dowloaded auto cad 2014 64 bit but  cant install it on my windows 10.please how do i rectify this situation.
Message 16 of 18
Mark.Lancaster
@Anonymous
Welcome to the community and hopefully my (or someone else) reply will be beneficially to you.
Not sure if you knew this or not, but this is a worldwide (public) user forum where users are assisting others. For future postings, do not include any personal information (such as your serial #) in any information that you share (include screen shots) with us.
Offically AutoCAd 2014 is not supported under Windows 10 but others have it running.   When you say "can't install it".  What's the problem?  Give us details of why you can't install it.   Are there any error messages?
Mark Lancaster
Message 17 of 18
Dear Sir, following the issue "required for 64 Bit Installer"
I went to the link, searched for product Autocad 2017 but it appeared to be as follow:
[An error occurred while processing your request.
 Reference #50.6f011a3a.1469246391.d75a9b3]
Please advise on what  should i do next...
Message 18 of 18
TravisNave
Don't do a search from the VirtualAgent. It sometimes fails. Drill down to it.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
