Installation & Licensing
3DSMAX INSTALLATION PROBLEM.
1 REPLY 1
491 Views, 1 Reply
Hi, I've tried to install 3dsMax 2012...like 10 times and always get this message: 1:5 2 adlmPITset Information failed 3:2, I know this issue is kind of normal, but the threads I've saw the error message is 3:9 not 3:2, I've tried to delete everything related to Autodesk (just like that help page says) but It keeps happening (besides, the only product that I've installed from Autodesk in my PC before this is SoftImage) and, when the installations finishes, there is no ADLM folder in Program Data, I don't know what is wrong, the only thing is that when I uncompressed the installer, the CRC from NetFrameWork failed but It did'nt stop, also I have NetFramework 4.... I've tried to run the installer in the Safe Mode but the installation fails even faster, when Direct X runtime is installing.
The Screenshot:
Please Autodesk, help me ;_;
By the Way:
I have Windows7 Home Premium 64-bit, 6gbs of RAM and Intelcore i5
Tags (3)
1 REPLY 1
TravisNave
This is a known issue and can be solved by using the Autodesk support knowledge base here:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13540825&linkID=9243182
Autodesk Forums:
Administrator Productivity
