Installation & Licensing
3dsmax freezing when closing
1 REPLY 1
jsebhex
417 Views, 1 Reply
Hello i got a serious problem when i need to close my 3dsmax the software freeze completely and i cant get it to close for more than 30 min i then use the task manager to kill the process. The curious thing is that the program perform perfectly and the problem only happen when i need to close it
I have tried to reinstall it twice and to remove the auto save when it close option to see if that was the problem to no avail.
Anyone got any idea how to fix that?
1 REPLY 1
TravisNave
in reply to: jsebhex
Check to see if your InfoCenter is hanging on close.  Might be able to kill wscommcntr2.exe or disable it in your application altogether.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
