Installation & Licensing
3dsmax 2012 SP2 wont install
3 REPLIES 3
1725 Views, 3 Replies
Hello
I'm trying to update the SP2 for our 3dsmax 2012 (with installed sp1, and hotfix 2 which installed with no problems).
But when lunching the SP2 installer I get a prompt that the required program is not installed and the installation aborts.
Using Windows 7 x64 and x64 version of 3dsmax.
3dsmax was at least once run with administrators account with administrative privileges.
This is a wmic product list for Autodesk:
Autodesk 3ds Max Design 2012 64-bit - English                   {52099562-C109-0409-BFF1-1C19149A8749}  Autodesk 3ds Max Design 2012 64-bit - English                   Autodesk                                14.1.2.210
Autodesk Backburner 2012.0.0                                    {3D347E6D-5A03-4342-B5BA-6A771885F379}  Autodesk Backburner 2012.0.0                                    Autodesk, Inc.                          2012.0.0
Autodesk Material Library 2011                                  {9DEABCB6-B759-4D52-92F8-51B34A2B4D40}  Autodesk Material Library 2011                                  Autodesk                                2.0.0.49
Autodesk Material Library 2011 Base Image library               {CD1E078C-A6B9-47DA-B035-6365C85C7832}  Autodesk Material Library 2011 Base Image library               Autodesk                                2.0.0.49
Autodesk Material Library 2011 Medium Image library             {975951E7-14D0-49AF-A630-89680D12D7F6}  Autodesk Material Library 2011 Medium Image library             Autodesk                                2.0.0.49
Autodesk Material Library 2012                                  {8F0837C2-EE09-4903-88F3-1976FE7FFF4E}  Autodesk Material Library 2012                                  Autodesk                                2.5.0.8
Autodesk Material Library Base Resolution Image Library 2012    {65420DC9-306E-4371-905F-F4DC3B418E52}  Autodesk Material Library Base Resolution Image Library 2012    Autodesk                                2.5.0.8
Autodesk Material Library Medium Resolution Image Library 2012  {B5751715-EC10-43D9-8C95-62E1368433EF}  Autodesk Material Library Medium Resolution Image Library 2012  Autodesk                                2.5.0.8
Tags (3)
3 REPLIES 3
nicolas.holst
Please make sure you've downloaded the 3ds Max Design 2012 SP2, if you try to install the 3ds Max 2012 SP2 that will not work.
You can download 3ds Max Design updates and services packs from: http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=10381720
If you run into an error 1334 when you install SP2 please see my post on MaxStation: error_1334_on_file_cudart64_32_16_dll_when_installing_service_pack_2_for_3ds_max_2012_3ds_max_design...
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Nicolas Holst
Support Specialist
Product Support
in reply to: nicolas.holst
Thanks... That's stupid but I missed that 🙂
I thought I did everything like the last time, but it seams that I overlooked that one... Now I now why it did look different in the patch folder 😛
sbomhardt
I have the same Problem. 3ds Max 2012 64 bit. Not design.
SP 1 installed, SP 2 doesn't. Is there a valid link to the update that works for me?
Thank you in advance.
Administrator Productivity
