I formerly had 3DS Max 2014 Student version installed on my computer. I purchased a professional version, uninstalled the student version, and installed the professional version with it's Serial Number and Product Key. However, even after this when I start 3DS Max it STILL says student version at the top. Any Ideas on how to resolve this??
Also make sure you don't use any of your educational designs in your commercial product as they will still be watermarked as educational. This is true even if even one part is referenced in. Be careful.
Hello. Uninstall all Autodesk Products through the Control Panel and then try to uninstall again using the MSFixit tool. http://support.microsoft.com/mats/Program_Install_and_Uninstall\
Then delete the tsf.data file. It will resemble this: ADSKFLEX_NUMBERS_TSF.data. It should be located here:
C:\ProgramData\FLEXnet
Then delete the residual Autodesk folders:
C:\Users\All Users\Autodesk
C:\Users\<the current user>\AppData\Local\Autodesk
C:\Users\<the current user>\AppData\Roaming\Autodesk
C:\Program Files\Common Files\Autodesk Shared
C:\Program Files\Autodesk
C:\ProgramData\Autodesk
Now install and register.
Thank you for taking part in our community!
