Installation & Licensing
New Member
0 Kudos
Post 11 of 14
Re: 3ds Max .NET framwork problem
06-21-2011 12:19 AM in reply to: DouglasLauritsen
I am sorry to differ with you.Running Vista 32 bit Home Premeium.  I have two other programs that utilize framework 3.5. I did all your little tips and get this -
I installed .NET framework 3.5 from Microsofts pages.
Then i unninstalled 3DsMAX 2011
Restarted computer.
Installed 3DsMAX again
Same message, ".NET framework not propperly installed..."
Ran cleanup utility
Re-installed framwork 3.5 2011
Uninstalled 3DsMAX
Checked other two programs requiring framework 3.5 - they run fine
Re-install 3dsMax 2011
Start  3ds Max 2011
AND STILL GET THIS MESSAGE -      ".NET framework not propperly installed..."
So explain to me jsut how other two programs that need frameword 3.5 to run work ok, and your program does not !!!!
Seems tome that with all the issues you have there are problems on YOUR end not ours. Not everybody have a screaming Geek computer to make this work. I am sad to say that after more than 15 hours and various installs and uninstalls this program does not work or install properly on three different computers.
New Member
0 Kudos
Post 12 of 14
11-02-2011 01:42 AM in reply to: woofgm
I get the same error message here when launching 3ds Max 2012 on Windows 7 Professional 64 bit. The system has been installed cleanly about three weeks ago, and, what's really strange, I did not change anything before the error message started to appear. The last update affecting the .NET framework was about two weeks ago via Windows Update and has installed .NET version 4. After that, 3ds Max ran fine for about two weeks, and since yesterday, it can't be launched anymore.
Currently, I am in a job hurry, so I have not had the time yet to try all the uninstalling, re-installing and cleanup-suggestions above. I'm using 3ds Max now on an old Win XP backup partition to finish my jobs. I will try all that stuff when there is a bit more time, but it's really strange that such things happen on a (nearly) freshly-installed Windows 7 machine.
I will let you know what I do and what works.
Johannes Eichberger
studio e
New Member
0 Kudos
Post 13 of 14
11-02-2011 10:09 AM in reply to: woofgm
Hello again,
I took some time now to try all the uninstalling and re-installing suggestions. Here is my whole story:
about 3 weeks BEFORE the error appeared:
- installed Windows 7 Professional 64-bit on a blank hard disk
- installed only the software I need for work (E-Mail client, Antivirus, FTP-client, VLC and so on)
- installed every update offered by Windows Update
- installed 3ds Max 2012 64-bit from CD
- downloaded and installed every hotfix and service pack found on the Autodesk website
- Max ran fine for about 3 weeks
Suddenly, the strange error message appeared:
"3ds Max has detected that the required .NET Framework version is not properly installed. The installed .NET Framework must be updated for the product to run. Please uninstall any pre-release versions of the .NET Framework, and either reinstall the application, or visit windowsupdate.com."
Then I tried the following steps:
- launched Windows Update, but it told me that my system is up to date
- noticed that the last update was a few days ago, but Max ran fine the last days
- launched system preferences -> uninstall programs, and uninstalled everything related to .NET
- downloaded and launched the .NET Framework Cleanup Tool from a link in a link in DouglasLauritsen's link
- rebooted
- tried to launch 3ds Max (just out of curiosity) - nothing happened, even no error message appeared
- launched Windows Update and re-installed everything related to .NET, several reboots in-between
- repeated until Windows Update told me that my system is up to date
- rebooted again
- launched 3ds Max - same error message: "...required .NET Framework version is not properly installed..."
- uninstalled 3ds Max, rebooted again
- during installation, 3 popups came up:
    1. (translation, see screenshot) The Windows Installer Service is not available. Possibly, another application is being installed. Quit all running installations, or reboot the Computer, and launch setup again.
    2. Windows Update bubble appeared in the lower right corner, telling me that there are .NET updates (but I thought, I had everything installed?!?)
    3. (translation, see screenshot) Unhandled exception in the application. [...] The File or Assebly "System.Core, Version=3.5.0.0, Culture=neutral, PublicKeyToken=b77a5c561934e089" or a dependency was not found. [...]
- but the installation finished
- launched Windows Update and installed the three .NET updates that the bubble has told me
- rebooted again, launched 3ds Max - same error message: "...required .NET Framework version is not properly installed..."
- checked Windows Update again, everything is up to date
What else can I try?!? I only can use 3ds Max from an old XP backup partition, but this can't be the only solution. And why does that all happen on a freshly installed machine?
Johannes Eichberger
studio e
New Member
0 Kudos
Post 14 of 14
04-03-2012 01:42 AM in reply to: woofgm
Same problem append To me  ive Try a restauration backup, update again with MS upd, uninstall, reinstall_ 3DSMAX,  but not  Luck.
 i dont have problem for lunch Maya, ScKetchbook pro,or MuDBox, softimage  etc...
Windows 7(x64)SP1 on RevoDrive X2 PCI-Express 100 Go-Intel Core i7 2600K 3400 Mhz-Corsair CWC-H50-*2 sli nVidia GTX 570 Gainward-G.Skill Kit Extreme3 4 x 4 Go PC12800 Ripjaws X CAS7+Turbulence Fan II- -MARVELL Raid 2xWestern Digital Caviar Black SATA 3.0 1To - 64 Mo-OCZ-SSD vertex 3 iops 120gb-Velociraptor 300 Gb-Roccat Valo +, Kone+ Enermax LEPA G900-MA - 900W-Antec Dark Fleet DF-85-ViewSonic VX2739wm-samsung synchmaster 172x-wacom tablet intuos 4..
Post to the Community
New Post
