We're trying to set up a few Autodesk packages that are part of the Education Master Suite 2015. We've installed LMTOOLS and set up the licence files but I can only get the AutoCAD packages to authenticate with it (AutoCAD, Mechanical, Civil, Artchitect, Inventor). For those I used the same serial number (network licence, 125 seat) and the EMS Product Key (651G1).
I've tried deploying Max/Maya using the EMS product key but they won't accept it as a valid key. I've tried using their own individual keys as well but they do not get a valid license from the server (Error 0,0,0).
Can someone shed some light on how I should go about doing this? Thanks in advance hopefully.
Running Server 2012 and LMTOOLS 11.12, client running Windows 7
Solved by Halvadzicz. Go to Solution.
Thanks for getting back with the solution; it happens, even to the best of us. There should be an "Accept as solution" button which will effectively close the thread, plus include it in search results (there's an option for returning solved threads).
