Installation & Licensing
3ds max installer won't run
1 REPLY 1
CaptainDuude
1871 Views, 1 Reply
I downloaded the 3ds 64bit installer but every time I try to run it, it would freeze everything up. It doesn't ever run the installer.
i do have a 64bit system. I can't even run and start the installer. I have spend 2 hours trying to find out the problem.
im not using the cd, I'm trying to install the trial for 3ds max
1 REPLY 1
kentw
in reply to: CaptainDuude
The UAC (User Account Control) should be disabled if this is a Windows 7 or Windows Vista operating System.
procedure located at website below:
http://windows.microsoft.com/en-AU/windows-vista/Turn-User-Account-Control-on-or-off
Install .NET Framework 4.0 separately and then attempt the install...refer procedure below...
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=16436702&linkID=9240617
Any Anti-virus software should be disabled at the time of install...
Clean out the Windows temp folder:
1. In windows click Start > Run.
2. In the Run box type %temp% and click “OK”. A windows explorer window will open and display the files in your TEMP directory.
3. Select and delete as many files as possible (there may be a few still in use).
4. Close the explorer window.
_________________________________________________________________
KarelCAD Application Support Specialist
Administrator Productivity
