Installation & Licensing
3ds max installation problem
22 REPLIES 22
Message 1 of 23
mmoody8
55992 Views, 22 Replies
I have big problem installing 3ds max.i am running Win7.
Attempt 1: choose 'save' option and downloaded 2 files. ran installer from desktop and entered serial number and product key. install started which seemed to go well for a few minutes and then took almost 30 minutes to move past first module (C++). Finally, downloaded several other modules and then i got error box saying 'monitor.exe'. a search showed that file is not on my machine. dismissed error and nothing lese happened.
Attempt 2: wanted a clean re-install so i uninstalled 2 C++ files and the install program (forget name but started with A...). no other files showed as uninstallable. when click on install this time box popped up so fast could not read it. went back online and tried 'run' option this time. got 'download complete', 'open autodesk 3ds max 2011 file 1 (2 of 2), 'downloading autodesk 3ds max 2011 file 1 (2 of 2)', and then 'calculating time remaining' where it hung for a half hour''
question is what next? should i remove all installed 3ds software and start over? if so, how? another approach?
please help...
mm
22 REPLIES 22
Message 2 of 23
DouglasLauritsen
in reply to: mmoody8
There are two components to this: 1) the download files and 2) the installer. I’ll assume you had successful download and extraction of the files required for Max. You can review this post if you wish to address a possible download or extraction issue or to understand the composition of the download.
Assuming the download and extraction were successful I’d recommend that you do this:
  1. Open Windows Explorer.
  2. Type %temp% in the address bar, then press Enter.
  3. Delete any files and folders that are a few days older than the last time you rebooted the computer.
  4. Reboot into Diagnostic Mode.
  5. Browse to “C:\Autodesk\ Autodesk_3ds_Max_2011_English_Win_32-64bit” and double click setup.exe to re-start the Installer.
  6. If it fails take screen shots and go to the Windows Explorer and gather up any new .log files to this thread. Then reboot and post them to this thread.
  7. If Successful Reboot without Diagnostic Mode.
Let us know how things work out.
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Message 3 of 23
mmoody8
in reply to: DouglasLauritsen
Douglas,
Thanks for your informative reply. I followed your suggestions but ran into a problem.
Installed:
Microsoft Visual C++ 2005 Redistributable (x86)  => O.K.
Microsoft Visual C++ 2008 SP1 Redistributable (x86)  =>  O.K.
DirectX Runtime Update  => O.K.
Autodesk Backburner 2008.1  => PROBLEM! => "The installer has detected that the following programs are running. monitor.exe. In order to complete installation these programs must be closed."
Using the WIN7 search I can find NO program named monitor.exe.
This is where things went wrong when I initiially tried to install 3ds Max. Your suggestions have worked very well to get me back to where things went wrong (thanks, I was wondering if that was possible) but now I need the next step.
The monitor.exe program is flagged with the error code but mayve it's another program that's actually causing the problem. If I knew what program to stop I would stop it and get on with the installation.
At this point I definitely need your help again.
Mitch Moody
Message 4 of 23
DouglasLauritsen
Hi Mitch,
Thank you for the additional information. Did you get this error when you were booted in Diagnostic Mode? This mode usually prevents additional processes from running.
I Googled “monitor.exe” and found many explanations that described it as a file for the Windows Server Operating System, LeapFrog Software, and even viruses. One source listed 64 sources for an executable with this name. I might download a new virus signature and perform a complete scan to be safe.
I have also researched cases our product support team has had on this and many recommendations are to stop this process from the task manager.
You can do this by:
   1. Pressing CTRL+SHIFT+ESC on the keyboard.
   2. Then select the Processes tab
   3. Right click monitor.exe, then choose End Process.
   4. Once stopped the Installer should run.
Let us know the results.
Douglas
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Message 5 of 23
mmoody8
Douglas,
You nailed my problem. Thanks so much.
I'll continue to say "nobody at any tech support line has helped me for 15 years." I'll just have to add "Except, of course, for Douglas at Autodesk."
Thanks again,
Mitch
Message 6 of 23
DouglasLauritsen
Hi Mitch,
Thank you for the kind words. I am happy to receive them and am glad to help.
Thank you for your follow up. It helps to add value to the community by adding confirmation for suggested resolutions.
Douglas
Douglas Lauritsen
Support Specialist
Product Support
Autodesk, Inc.
Message 7 of 23
ak
Community Visitor
Running Windows 7 x64 the installation seemed to go fine.  When I try to run 3Ds Max Design I first got an error saying 'Missing d3dx9_43.dll file" it was in sysWOW64 dir. but missing in system32 so I added it.  Now I get an application error "The application was unable to start correctly (0xc000007b). Click OK to close the application."
What do I need to do to fix.
Michelle
Tags (1)
Message 8 of 23
jandebacker
Ik had het zelfde probleem tijdens de installatie van de Entertainment Creation Suite for Education 2012.
Monitor.exe was niet te stoppen en niet te vinden. Dat de oplossing zo simpel is 🙂 en dat ik na de 7de poging succesvol bezig ben met de suite te installeren is te danken aan deze gouden tip.
Mijn oprechte dank.
Jan
Message 9 of 23
JimBeard3129
I'm having the same issue with a brand new powerful computer- and I know the installation media is good, I used it before. Need a solution!
jb
Message 10 of 23
mitchellavery
if anyone is still having problems with d3dx9_43.dll, try installing/reinstalling directx 9.  Replaced the .dll in system32 and in my max folder and works perfectly
Message 11 of 23
Even easier - download the DirectX End-User Runtime Web Installer from the Microsoft Website http://www.microsoft.com/download/en/details.aspx?displaylang=en&id=35
After I installed it the d3dx9_43.dll not found message disappeared and I could run 3ds.
Message 12 of 23
ivybec
in reply to: jamiesanders
This solved my problem!
Ivy
Message 13 of 23
thanks for you..
Message 14 of 23
ivaring
Well Mr. Ramdass, as you must know Windows 8 Pro has a more recent version that this one, so, this couldnt solve the problem.
I assume Autodesk tested all version first of letting them see the light, this is causing a lot of problem a loose of time.
Message 15 of 23
antoniole96
I cannot install 3DS max because it is saying monitor.exe needs to be closed to complete the installation. What do I do?
Message 16 of 23
photogroup
in reply to: mitchellavery
That fixed my problem also.
Thanks!
Message 17 of 23
Gaveeebruce
Dear Sir/Madam
I have currently been introduced to 3ds max in college and I'm struggling though the Installation part. I have it downloaded onto my laptop but the set up im having problems with it is saying
CRC failed in x86/max/max1/.cab
Unexpected end of archive
I don't have a absolute clue what this means and I'd just like to get it all installed and catch up in my class. If anyone has any insight on this anything will be appreciated.
I've downloaded Autodesk 3ds Max 2012 32 bit
Thank You
Message 18 of 23
Hruyardi
Perfecta solución, Ctrl  + shift + Esc, soluciona el problema de monitor.exe   Gracias!
Message 19 of 23
mc170770
ola, Douglas, obrigado, deu certo a instalação agora.
Message 20 of 23
rahuleditor832
when starting 3d max english 2016  it stop on std/bipped.dll and hangs on there only .
all other version like brazil version running smoothly. iam running win 8
m
Administrator Productivity
