Hi, there ..
I used to work on 3Ds max design 2014 for a quite while ..
then I decided to upgrade to 2015 ..
I installed 2015, and I made sure that evertything is okay .. then I uninstalled the 2014 version to spare space on my hdd
after uninstalling the 2014 version, all 3ds max files on my machine don't show the 3ds max icon for no reason !!!! ( check the attatchment )
i tried to figure that out, with no luck !!!
I tried to uninstall the 2015 version and reinstall it. and it didn't work !!
I know that it's not a major problem .. but it's really annoying !!!!
( I use windows 8.1 btw )
Solved by ggarza. Go to Solution.
Hello. This is just a Windows file association. It was removed from your file type. It’s a Windows thing. Right click a file with the problem and click “Properties”. On the “General” tab, next to the “Opens with” field, click “Change…”
Select Max in the list, or navigate to the Max startup exe in the install directory. That should be it.
Thank you for taking part in our community!
Hi, there
Thank you for your response,
but in fact that doesn't solve the problem ...
the 3ds max exe file it self doesn't have the icon ..
check the attachement
regards
Was there ever a fix on this. The SAME exact thing happended to me. The solution you've given here is incorrect (read his reply below). The actual .EXE has a Default Windows Icon... so every file associated to it shares the same icon. The odd thing is the icon exist in a way where the shortcuts are able to use it... just the not the actual EXE and MAX files.
I spent nearly all day trying to fix this the other day. I went as far as completely removing the program and others associated with... then re-installing as cleanly as possible.... It didn't work.
This needs to addressed.
I agree that this solution is useless!
Pls. review the actual problem before providing such solution.
I have exactly thesame issue and this is very disapointing matter.
Here is what I've done for a fix. Keep in mind that the EXE itself will remain without an icon. What I discovered with some icon utility is the max.exe doesn't contain an icon for general index (or the 0, index. It has others in the 1,2,3,4 etc... just not the 0 index. And that is the one that is automatically assigned. That is likely why the max.exe has the general application icon... Windows sees the blank icon in the 0 index, thus assigning it as such. That said..
You can however fix the 3dsm document icons. Use your own precaution... you must edit the registry.
This seems like alot, but most of the steps are more for someone who has never been in there registry.
Good luck.. it worked for me.
Man, that was so freakin brilliant !!!
good job !! you didn't give jus like I did ..
I almost searched everywhere .. and I thought it's impossible to solve ..
it's very easy and quick to do .. and it's worth every step in the procedure to do !!
salut for your persistency !!
have a good one, mate !!
hello,
i have the same problem, and tried doing the registry fix you sudgested.
after expending the HKEY_CLASSES_ROOT i looked for the "max_auto_file" and it wasn't there 😞
thanx
guy
for me it didn't work at all. did every step carefully, max_auto_file was there, DefaultIcon was not, created, copied the path to the icon, restarted, nothing.
windows 10
Im only writing this for people who look for this problem in the future, After doing these steps if it doesn't work for you, Click on the file with the missing thumb nail and go to Open with, Then switch it to any other program then switch it right back to max. That fixed it for me.
This just happened to me uninstalling 2016 so as to leave just the 2017 release on my workstation. 3 years of releases later. Typical.
i did every thing on the registery and even tried re-installing 3ds max but it didn't work and 3ds max files still without 3ds max icon.
i eventually tried to delete the "max_auto_file" fom registery and i did a clear uninstall and deleted all of max files from local and roaming and everything then i re-installed 3ds max after that ,as ithought it should create the deleted registegy it self during the installation but it didn't so i created new registery key at the same position with the exact name "max_auto_file" and with the subkeys of "defaulticon" and "shell" with the values that they should be but also that didn't work so what else should i do.
