Installation & Licensing
3ds Max design 2014 failed to install error 1619
1 REPLY 1
920 Views, 1 Reply
I'm installing the student version 2014, and this always pops up,i have assignments coming up and i really need this. I had the same problem when i tried instaling 2012 and 2013 version. I tried deleting the redistrebutable files from microsoft, switching off the untivirus, my windows is up to date, i also tried installing  the nromal 3d max,but nothing(the only difference is that sometimes i get a 1603 error instead) i dont know what else to do:( But my Autocad 2011 works fine though and didnt have any problems.
I've attached my results.
1 REPLY 1
TravisNave
Welcome to the Forums!
Installing .NET Framework Runtime 4.0 KB2468871
It's failing on the .NET 4.0.  You might have to remove it and reinstall it completely.  Or use the .NET Cleanup.
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Administrator Productivity
