Installation & Licensing
3ds Max crashes every time I try to open it
2 REPLIES 2
333 Views, 2 Replies
Just purchased and installed a monthly rental of 3Ds max, and i cant even open it, it simply crashes everytime... any help would be much appreciated...
2 REPLIES 2
TravisNave
You should probably start at your video card driver.  Make sure you are using an updated certified driver.
http://usa.autodesk.com/adsk/servlet/syscert?siteID=123112&id=18844534&results=1&stype=graphic&produ...
Good Luck!
Autodesk Forums:
Many thanks for the suggestions! turns out it was a windows driver issue, ran the windows update a few times, and it seems to have fixed the crashes!
Administrator Productivity
