Installation & Licensing
3ds Max application has stopped working
8 REPLIES 8
Message 1 of 9
21968 Views, 8 Replies
Hello, last night I downloaded the student version of Autodesk 3ds Max 2012. After the program installed, I tried to open it.
1. A message popped up saying "3ds Max application has stopped working"
2. Then it goes on to shows two options, Debug and Close program.
I installed the Windows 32-Bit version. My computer also meets the system requirements (I think). I disabled User Access Control, and I disabled Data Execution Prevention for it. I have Windows Vista.
My specs:
Processor: Intel(R) Core(TM)2 Duo
CP P8600 @ 2.40GHz
Memory (RAM): 4.00GB
System Type: 32-bit Operating System
8 REPLIES 8
Message 2 of 9
VinodBalasubramanian
This looks like a profile corruption issue. Can you create a new user account and check whether you could able to run your 3ds Max on it.
______________________________________________________________
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
Vinod Balasubramanian
AutoCAD Industry Support & Escalation Lead
Message 3 of 9
hey guys i found the solution, here is what you do, go to
C:Users/******/Appdata/Local/autodesk--- (make show you unhide your folders so that you can view the appdata and other folder that are hidden)
and then delete autodesk, then start 3ds max 2012 or what ever version you use
Message 4 of 9
Thank Macchu...........thank u very much
Message 5 of 9
I have tested your solution but after deletion autodesk 3ds max 2013 is not runing.
Please Help ...
Message 6 of 9
thank... very much
Message 7 of 9
Thank u so muchSmiley Wink
Message 8 of 9
Rimozan
i have this message only when i open one of my 3ds max work files but in startup it works normal don't know how ! and i didn't find this folder so what can i do !
Tags (1)
Message 9 of 9
C/App Data/Local/Autodesk/3dsMax/2012 - 64bit
You need delete folder. That is ok
Administrator Productivity
