Installation & Licensing
3ds Max 2015 with student license error 1603
13 REPLIES 13
Message 1 of 14
alex.mrkulic
2122 Views, 13 Replies
So, 3ds Max 2015 installation will not work, it always throws a 1603.
I have Windows 7 64-bit
I tried
Turning off UAC
Turning of antivir
checking if NFTS short name creation was allowed
Not installing with service pack
emptying temp folder
checking folder priviliges
None of these fixed it.
I also tried uninstalling service pack for windows 7, because I used to have problems with some vcredist packages, but it hasn't been an issue, and that didn't fix it. I'm all out of options, and would appriciate any tips, or anything.
2015/1/7:19:58:48    Neroxen    NEROXEN-PC    === Setup started on NEROXEN-PC by Neroxen ===
2015/1/7:19:58:48    Neroxen    NEROXEN-PC    Path_Length: 148
2015/1/7:19:58:48    Neroxen    NEROXEN-PC    Current Directory C:\Users\Neroxen\AppData\Local\Temp\_AI4E20.tmp
2015/1/7:19:58:48    Neroxen    NEROXEN-PC    Launch
2015/1/7:19:58:49    Neroxen    NEROXEN-PC    PageOpen    LaunchDialog
2015/1/7:19:58:51    Neroxen    NEROXEN-PC    PageOpen    LicenseDialog
2015/1/7:19:58:56    Neroxen    NEROXEN-PC    PageOpen    ProductInfoDialog
2015/1/7:19:59:11    Neroxen    NEROXEN-PC    PageOpen    ProductSelectionDialog2
2015/1/7:19:59:20    Neroxen    NEROXEN-PC    PageOpen    FullProgressDialog
2015/1/7:19:59:20    Neroxen    NEROXEN-PC    Installing Autodesk® Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/1/7:19:59:29    Neroxen    NEROXEN-PC    Install    Autodesk® Material Library 2015    Succeeded
2015/1/7:19:59:29    Neroxen    NEROXEN-PC    Installing Autodesk® Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/1/7:19:59:41    Neroxen    NEROXEN-PC    Install    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2015/1/7:19:59:41    Neroxen    NEROXEN-PC    Installing Autodesk® Material Library 2015 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/1/7:19:59:56    Neroxen    NEROXEN-PC    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2015/1/7:19:59:58    Neroxen    NEROXEN-PC    Installing Autodesk® 3ds Max 2015:  TRANSFORMS="C:\Users\Neroxen\AppData\Local\Temp\_AI4E20.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2015/1/7:20:00:20    Neroxen    NEROXEN-PC    Install    Autodesk® 3ds Max 2015    Failed    Installation aborted, Result=1603
2015/1/7:20:00:30    Neroxen    NEROXEN-PC    Rollback    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2015/1/7:20:00:49    Neroxen    NEROXEN-PC    Rollback    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2015/1/7:20:01:07    Neroxen    NEROXEN-PC    Rollback    Autodesk® Material Library 2015    Succeeded
2015/1/7:20:01:08    Neroxen    NEROXEN-PC    PageOpen    InstallCompleteDialog
2015/1/7:20:04:23    Neroxen    NEROXEN-PC    === Setup ended ===
Tags (1)
13 REPLIES 13
Message 2 of 14
alex.mrkulic
in reply to: alex.mrkulic
Anyone?
Message 3 of 14
DarrenP
please read this on info for error 1603 and the many causes of this and possible solutions
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-1...
DarrenP
Message 4 of 14
alex.mrkulic
in reply to: DarrenP
As is apparent from my main post, I tried all of these. It didn't work. The problem still persists
Message 5 of 14
asburyj
Hi Alex,
To help me isolate the cause of the install failure, can you attach a copy of your detialed install log file? The logs will be generated in the TEMP directory which can be accessed by typing '%temp%' in the START > RUN. Please locate the logs which will have a naming convention of "Product Name Install.log" , where  "Product name" is the name and release year of the software. The 3DS max install logs can get rather large so you may need to zip the file first.
Jeffry Asbury
Message 6 of 14
alex.mrkulic
in reply to: asburyj
Yes, it's already attached to the main post.
Message 7 of 14
alex.mrkulic
Well, apparently it wasn't, and I wasn't able to edit my earlier post in time. But here it is, packed in a .rar.
Message 8 of 14
asburyj
The log shows CustomAction MRSetService returned actual error code 1603
This means the mentalray satellite service cannot be created for some reason. One known cause of this error is a missing "Services" file from C:\Windows\System32\drivers\etc. If that file is missing it can be recovered with a windows OS repair or by simply copying it over from a system that still has the file. If that file isn't missing it's hard to say why it would be failing. If you aren't going to use mental ray for rendering you may want to just try taking that out of the installer. Here's some steps to follow
1.) Download and install orca msi editing tool http://www.technipages.com/download-orca-msi-editor
2.) Copy the install media for 3ds max to a local drive or navigate to the downloaded installer directory. Find the install msi for 3ds Max, usually  x64/max/3dsmax.msi
3.) Right click the msi and choose edit in orca
4.) In "Custom Actions" Search for the line MRSetService and delete it. Close Orca and save the changes.
5.) Run the 3ds Max install again.
If this is the only spot the install is getting struck in it should complete.
Jeffry Asbury
Message 9 of 14
alex.mrkulic
Thank you! That helped me fix it.
I fixed the problem by giving my account (which is admin) the ownership of that file temporarily. After that, the installation went fine! It's weird how running the setup as admin didn't get past this...
Message 10 of 14
asburyj
The default permission for that file should allow administrators or edit it but it's possible it had it's permissions corrupted or was locked for editing by some other process. Either way I am glad you were able to move past it.  Cheers!
Jeffry Asbury
Message 11 of 14
bhuvna14
I am unable to install 3ds max on my laptop.
It says your installation is successfully but non of the packages is installed. It gives failed to install.
please help me with this as I need to convert some inventor files to 3ds urgently. or if there is any other way to convert .ipl to .3ds format.
regards,
bhuvna14
Message 12 of 14
philip.s
in reply to: bhuvna14
Hello @bhuvna14 and welcome to the community!
Typically you need to look through the installation log to find the culprit for a 1603 error. I've provided some reference links for your convenience.
Error 1603 during installation of Autodesk software
Location of the log files generated by the installation of an Autodesk product
If you're in the need of some quick conversion assistance, try posting the file / request in the 3ds Max forum.
Message 13 of 14
bhuvna14
in reply to: philip.s
HI,
I tired and it is still not working.I even tired installing on different desktops and laptops but the error remains.
All I want is to convert two inventor files I have into 3ds format so that i can use it in my code.
Can anyone help me who has 3ds installed.
Please let me know as early as possible as on monday I have a demo to give.
Thank you in advance.
Bhuvna Kakodia
Message 14 of 14
kaurn9169
Administrator Productivity
