Dear all,
I have successfully downloaded 3DSMAX 2015 (Desktop subscription license) on my hard disk.
When launching setup.exe from my hard drive C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\setup.exe, a page showing Autodesk 3dsmax 2015 opens and starts initializing then stops without any error message.
The log message is the following:
2014/11/3:15:42:31 Frédéric André FRÉDÉRICANDRÉ === Setup started on FRÉDÉRICANDRÉ by Frédéric André ===
2014/11/3:15:42:31 Frédéric André FRÉDÉRICANDRÉ Path_Length: 148
2014/11/3:15:42:31 Frédéric André FRÉDÉRICANDRÉ Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/11/3:15:42:31 Frédéric André FRÉDÉRICANDRÉ Launch
2014/11/3:15:42:31 Frédéric André FRÉDÉRICANDRÉ CommandLine
2014/11/3:15:42:31 Frédéric André FRÉDÉRICANDRÉ Current Directory C:\Users\FRDRIC~1\AppData\Local\Temp\_AI3DFA.tmp
2014/11/3:15:43:13 Frédéric André FRÉDÉRICANDRÉ === Setup ended ===
I use Windows 7, have .NET 4.0, have stopped Norton 360, started setup.exe as administrator.
Any help please?
Frederic
Dear David,
I use Windows 7 French version.
What kind of other log file do you mean please?
I attach 3 log files:
1) 3dsMax_2015_Setup.log
2) AutodeskDownloadManager
3) Autodesk_Showcase_2014
Thank you for your assistance
Reboot your computer and try the install again.
Do the following as well.
http://upandready.typepad.com/up_and_ready/2013/04/quick-start-general-installation-workflow.html
If you are running a free AV, I would uninstal it.
http://upandready.typepad.com/up_and_ready/2014/08/quick-start-security-anti-virus-software.html
Dear David,
I tried it to the same result.
I am the administrator on my PC an HP Pavilion dv6 with an intel i7,
I deleted %TEMP%,
I silenced NORTON 360, disabled the firewall and antivirus, (I don't have a free AV),
I disabled the User Account Control (UAC) and
I launched again setup.exe which started initializing then stopped.
See %TEMP% 3dsMax_2015_Setup.log hereunder:
2014/11/3:20:00:09 Frédéric André FRÉDÉRICANDRÉ === Setup started on FRÉDÉRICANDRÉ by Frédéric André ===
2014/11/3:20:00:09 Frédéric André FRÉDÉRICANDRÉ Path_Length: 148
2014/11/3:20:00:09 Frédéric André FRÉDÉRICANDRÉ Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/11/3:20:00:09 Frédéric André FRÉDÉRICANDRÉ Launch
2014/11/3:20:00:09 Frédéric André FRÉDÉRICANDRÉ CommandLine
2014/11/3:20:00:09 Frédéric André FRÉDÉRICANDRÉ Current Directory C:\Users\FRDRIC~1\AppData\Local\Temp\_AI6D4.tmp
2014/11/3:20:00:38 Frédéric André FRÉDÉRICANDRÉ === Setup ended ===
Any other lead please?
Can you create a new account that doesn't have any accents or spaces in it. Make sure account is Admin and try the install again.
Dear David,
I created a new administrator account without accents and spaces.
When setup.exe was launched, this time appeared a window "Autodesk component stopped working" with the following problem details:
Signature du problème :
Nom d’événement de problème: APPCRASH
Nom de l’application: Setup.exe_unknown
Version de l’application: 8.0.46.0
Horodatage de l’application: 52936f64
Nom du module par défaut: StackHash_c640
Version du module par défaut: 0.0.0.0
Horodateur du module par défaut: 00000000
Code de l’exception: 00000000
Décalage de l’exception: 00000000
Version du système: 6.1.7601.2.1.0.768.3
Identificateur de paramètres régionaux: 1036
Information supplémentaire n° 1: c640
Information supplémentaire n° 2: c640498c1d3a2e9e66ac88654f590f29
Information supplémentaire n° 3: 38b6
Information supplémentaire n° 4: 38b60b6f715a8e1a46d7a8e74a686c61
Lire notre déclaration de confidentialité en ligne :
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x040c
Si la déclaration de confidentialité en ligne n’est pas disponible, lisez la version hors connexion :
C:\Windows\system32\fr-FR\erofflps.txt
End of error message
When looking at the %TEMP% log:
2014/11/3:20:58:20 AdminFRED FRÉDÉRICANDRÉ === Setup started on FRÉDÉRICANDRÉ by AdminFRED ===
2014/11/3:20:58:20 AdminFRED FRÉDÉRICANDRÉ Path_Length: 148
2014/11/3:20:58:20 AdminFRED FRÉDÉRICANDRÉ Current Directory C:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/11/3:20:58:20 AdminFRED FRÉDÉRICANDRÉ Launch
2014/11/3:20:58:20 AdminFRED FRÉDÉRICANDRÉ CommandLine
2014/11/3:20:58:20 AdminFRED FRÉDÉRICANDRÉ Current Directory C:\Users\ADMINF~1\AppData\Local\Temp\_AI4C0E.tmp
2014/11/3:20:59:10 AdminFRED FRÉDÉRICANDRÉ === Setup ended ===
