I am trying to reinstall 3ds max2015 but it fails at the end.
The software 3ds max 2015 was installed previously on my computer but I had to uninstall it for some space, now I am re installing it but it shows my the end that 3ds max2015 failed to install.
I have already uninstalled all other files after uninstalling manually but still it didnt work.
Please someone advise.
Thank you.
Solved by TravisNave. Go to Solution.
Post your installation log file.
Install Autodesk® Material Library 2015 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
I would recommend that you try downloading your product using the virtual assistant by following the directions here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to-...
