hello
the 3ds max 2015 installation abordes every time.
i tried a lot of soloutions postet in this forum but nothing worked.
attached the installlog
thanks for the help
Solved by asburyj. Go to Solution.
The error is showing as follows
Action start 22:00:31: MRSetService.
CustomAction MRSetService returned actual error code 1603 (note this may not be 100% accurate if translation happened inside sandbox)
This means the mentalray satelite service cannot be created for some reason. If you aren't going to use mental ray for rendering you may want to just try taking that out of the installer. Here's some steps to follow
1.) Download and install orca msi editing tool http://www.technipages.com/download-orca-msi-editor
2.) Copy the install media for 3ds max to a local drive or navigate to the downloaded installer directory. Find the install msi for 3ds Max, usually x64/max/3dsmax.msi
3.) Right click the msi and choose edit in orca
4.) In "Custom Actions" Search for the line MRSetService and delete it. Close Orca and save the changes.
5.) Run the 3ds Max install again.
If this is the only spot the install is gettin struck in it should complete.
Pabloibra9 that setup.ini file doesn't tell us anything. If you are having trouble with an install please connect the logs. The logs will be generated in the TEMP directory which can be accessed by typing '%temp%' in the START > RUN. Please locate the logs which will have a naming convention of "Product Name Setup.log" and "Product Name Install.log" , where "Product name" is the name and release year of the software, and post them back up here. You may need to zip them to make them small enough
perdona pero no sabia muy bien que archivos eran , adjunto lo que he encontrado ya que no se me ha instalado casi nada porque me aparece "network failured" al principio de la instalación y se cancela la instalación.
Tengo windows 8.1 , 8Gb de Ram , Mas de 700 Gb de disco duro
Lo necesito para mis estudios y he mirado si es solamente con la version 2015 , pero me ocurre igual con todas las versiones , con Maya me pasa igual
Gracias
Can you try downloading from the direct download links on our virtual agent as a workaround?
Select the 2nd Choice "Download Links "
Select your product
You are now presented with the choice to download your software.
MUCHISIMAS GRACIAS , me sirvió 100% pero me gustaria saber que fallaba antes para que de la otra manera no me permitiese instalar el programa. Gracias
There are different install options for our software. The trial and install now options download the software at the same time as it's installing and that network failure means the network interupted during the process. I like to recommend the full download if there are connection problems because you know if the download completed nothing will interrupt your install.
