Installation & Licensing
3ds Max 2015 install error 1603
1 REPLY 1
x3ask
785 Views, 1 Reply
Overall progress: 8 of 15
OS Windows 7 Pro
Happens with normal and admin accounts.
Error msg: http://s30.postimg.org/r0twcqbpd/error.png
Installation log file: http://dpaste.com/1JDQ2KE.txt
Spoiler
2014/10/21:15:42:26    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/21:15:42:26    compaq    COMPAQ    Path_Length: 148
2014/10/21:15:42:26    compaq    COMPAQ    Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/10/21:15:42:26    compaq    COMPAQ    Launch
2014/10/21:15:42:26    compaq    COMPAQ    CommandLine
2014/10/21:15:42:26    compaq    COMPAQ    Setup    Windows update reboot is pending
2014/10/21:16:04:00    compaq    COMPAQ    Setup    Autodesk 3ds Max 2015    Will restart automatically.
2014/10/21:16:04:01    compaq    COMPAQ    === Setup ended ===
2014/10/21:16:30:18    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/21:16:30:18    compaq    COMPAQ    Path_Length: 148
2014/10/21:16:30:18    compaq    COMPAQ    Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/10/21:16:30:18    compaq    COMPAQ    Launch
2014/10/21:16:30:18    compaq    COMPAQ    CommandLine
2014/10/21:16:30:18    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AIF121.tmp
2014/10/21:16:31:01    compaq    COMPAQ    === Setup ended ===
2014/10/21:16:30:27    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/21:16:30:27    compaq    COMPAQ    Path_Length: 148
2014/10/21:16:30:27    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AIF121.tmp
2014/10/21:16:30:27    compaq    COMPAQ    Launch
2014/10/21:16:31:01    compaq    COMPAQ    PageOpen    LaunchDialog
2014/10/21:16:31:20    compaq    COMPAQ    PageOpen    LicenseDialog
2014/10/21:16:31:20    compaq    COMPAQ    PageOpen    ProductSelectionDialog2
2014/10/21:16:31:46    compaq    COMPAQ    PageOpen    LicenseDialog
2014/10/21:16:31:46    compaq    COMPAQ    PageOpen    LaunchDialog
2014/10/21:16:31:49    compaq    COMPAQ    PageOpen    LicenseDialog
2014/10/21:16:32:13    compaq    COMPAQ    PageOpen    ProductInfoDialog
2014/10/21:16:32:47    compaq    COMPAQ    PageOpen    ProductSelectionDialog2
2014/10/21:16:34:01    compaq    COMPAQ    === Setup ended ===
2014/10/21:16:35:15    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/21:16:35:15    compaq    COMPAQ    Path_Length: 148
2014/10/21:16:35:15    compaq    COMPAQ    Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/10/21:16:35:15    compaq    COMPAQ    Launch
2014/10/21:16:35:15    compaq    COMPAQ    CommandLine
2014/10/21:16:35:15    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AI7ACA.tmp
2014/10/21:16:35:24    compaq    COMPAQ    === Setup ended ===
2014/10/21:16:35:21    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/21:16:35:21    compaq    COMPAQ    Path_Length: 148
2014/10/21:16:35:21    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AI7ACA.tmp
2014/10/21:16:35:21    compaq    COMPAQ    Launch
2014/10/21:16:35:24    compaq    COMPAQ    PageOpen    LaunchDialog
2014/10/21:16:35:26    compaq    COMPAQ    PageOpen    LicenseDialog
2014/10/21:16:35:29    compaq    COMPAQ    PageOpen    ProductInfoDialog
2014/10/21:16:35:42    compaq    COMPAQ    PageOpen    ProductSelectionDialog2
2014/10/21:16:36:00    compaq    COMPAQ    PageOpen    FullProgressDialog
2014/10/21:16:36:00    compaq    COMPAQ    Installing Microsoft Visual C++ 2005 Redistributable (x86): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\compaq\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/10/21:16:36:38    compaq    COMPAQ    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Succeeded
2014/10/21:16:36:38    compaq    COMPAQ    Installing Microsoft Visual C++ 2005 Redistributable (x64): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2005SP1ATL\vcredist_x64.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~2.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\compaq\AppData\Local\Temp\vcredist_x64_2005.log"" "
2014/10/21:16:37:04    compaq    COMPAQ    Install    Microsoft Visual C++ 2005 Redistributable (x64)    Succeeded
2014/10/21:16:37:04    compaq    COMPAQ    Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/10/21:16:37:15    compaq    COMPAQ    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/10/21:16:37:15    compaq    COMPAQ    Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/10/21:16:37:22    compaq    COMPAQ    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/10/21:16:37:22    compaq    COMPAQ    Installing DirectX® Runtime: "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/21:16:37:35    compaq    COMPAQ    Install    DirectX® Runtime    Succeeded
2014/10/21:16:37:35    compaq    COMPAQ    Installing Autodesk® Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:16:38:25    compaq    COMPAQ    Install    Autodesk® Material Library 2015    Succeeded
2014/10/21:16:38:26    compaq    COMPAQ    Installing Autodesk® Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:16:39:12    compaq    COMPAQ    Install    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2014/10/21:16:39:12    compaq    COMPAQ    Installing Autodesk® Material Library 2015 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:16:40:30    compaq    COMPAQ    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2014/10/21:16:40:30    compaq    COMPAQ    Installing Autodesk Application Manager: "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\x86\ADAPPLICATIONMANAGER\AdApplicationManager-WebInstaller.exe"
2014/10/21:16:42:05    compaq    COMPAQ    Install    Autodesk Application Manager    Succeeded
2014/10/21:16:42:28    compaq    COMPAQ    Installing Autodesk® 3ds Max 2015:  TRANSFORMS="C:\Users\compaq\AppData\Local\Temp\_AI7ACA.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" INSTALLDIR="E:\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:17:23:07    compaq    COMPAQ    Install    Autodesk® 3ds Max 2015    Failed    Installation aborted, Result=1603
2014/10/21:17:23:08    compaq    COMPAQ    Rollback    Autodesk Application Manager    Failed    Failure is ignored, Result=1619
2014/10/21:17:23:20    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2014/10/21:17:23:23    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2014/10/21:17:23:47    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015    Succeeded
2014/10/21:17:23:47    compaq    COMPAQ    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/10/21:17:23:47    compaq    COMPAQ    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/10/21:17:23:47    compaq    COMPAQ    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/10/21:17:23:47    compaq    COMPAQ    Rollback    Microsoft Visual C++ 2005 Redistributable (x64)    Failed    Installation aborted, Result=1619
2014/10/21:17:23:47    compaq    COMPAQ    Rollback    Microsoft Visual C++ 2005 Redistributable (x86)    Failed    Installation aborted, Result=1619
2014/10/21:17:23:57    compaq    COMPAQ    PageOpen    InstallCompleteDialog
2014/10/21:17:24:58    compaq    COMPAQ    === Setup ended ===
2014/10/21:17:25:37    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/21:17:25:37    compaq    COMPAQ    Path_Length: 148
2014/10/21:17:25:37    compaq    COMPAQ    Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/10/21:17:25:37    compaq    COMPAQ    Launch
2014/10/21:17:25:37    compaq    COMPAQ    CommandLine
2014/10/21:17:25:37    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AI96F2.tmp
2014/10/21:17:25:51    compaq    COMPAQ    === Setup ended ===
2014/10/21:17:25:42    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/21:17:25:42    compaq    COMPAQ    Path_Length: 148
2014/10/21:17:25:42    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AI96F2.tmp
2014/10/21:17:25:42    compaq    COMPAQ    Launch
2014/10/21:17:25:47    compaq    COMPAQ    PageOpen    LaunchDialog
2014/10/21:17:25:50    compaq    COMPAQ    PageOpen    LicenseDialog
2014/10/21:17:25:54    compaq    COMPAQ    PageOpen    ProductInfoDialog
2014/10/21:17:26:25    compaq    COMPAQ    PageOpen    ProductSelectionDialog2
2014/10/21:17:26:39    compaq    COMPAQ    PageOpen    FullProgressDialog
2014/10/21:17:26:40    compaq    COMPAQ    Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/10/21:17:26:42    compaq    COMPAQ    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/10/21:17:26:42    compaq    COMPAQ    Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/10/21:17:26:43    compaq    COMPAQ    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/10/21:17:26:43    compaq    COMPAQ    Installing DirectX® Runtime: "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/21:17:26:59    compaq    COMPAQ    Install    DirectX® Runtime    Succeeded
2014/10/21:17:27:00    compaq    COMPAQ    Installing Autodesk® Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:17:28:00    compaq    COMPAQ    Install    Autodesk® Material Library 2015    Succeeded
2014/10/21:17:28:01    compaq    COMPAQ    Installing Autodesk® Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:17:29:51    compaq    COMPAQ    Install    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2014/10/21:17:29:52    compaq    COMPAQ    Installing Autodesk® Material Library 2015 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:17:31:11    compaq    COMPAQ    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2014/10/21:17:31:21    compaq    COMPAQ    Installing Autodesk® 3ds Max 2015:  TRANSFORMS="C:\Users\compaq\AppData\Local\Temp\_AI96F2.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" INSTALLDIR="E:\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:18:13:55    compaq    COMPAQ    Install    Autodesk® 3ds Max 2015    Succeeded
2014/10/21:18:13:56    compaq    COMPAQ    Installing Autodesk® Populate Data for 3ds Max 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/21:18:18:52    compaq    COMPAQ    Install    Autodesk® Populate Data for 3ds Max 2015    Failed    Installation aborted, Result=1602
2014/10/21:18:20:35    compaq    COMPAQ    Rollback    Autodesk® 3ds Max 2015    Succeeded
2014/10/21:18:20:50    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2014/10/21:18:20:54    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2014/10/21:18:21:17    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015    Succeeded
2014/10/21:18:21:17    compaq    COMPAQ    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/10/21:18:21:17    compaq    COMPAQ    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/10/21:18:21:18    compaq    COMPAQ    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
2014/10/21:18:21:23    compaq    COMPAQ    PageOpen    InstallCompleteDialog
2014/10/21:18:21:37    compaq    COMPAQ    === Setup ended ===
2014/10/26:10:12:29    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/26:10:12:29    compaq    COMPAQ    Path_Length: 148
2014/10/26:10:12:29    compaq    COMPAQ    Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/10/26:10:12:29    compaq    COMPAQ    Launch
2014/10/26:10:12:29    compaq    COMPAQ    CommandLine
2014/10/26:10:12:29    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AIE57E.tmp
2014/10/26:10:13:13    compaq    COMPAQ    === Setup ended ===
2014/10/26:10:12:37    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/26:10:12:37    compaq    COMPAQ    Path_Length: 148
2014/10/26:10:12:37    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AIE57E.tmp
2014/10/26:10:12:37    compaq    COMPAQ    Launch
2014/10/26:10:13:12    compaq    COMPAQ    PageOpen    LaunchDialog
2014/10/26:10:44:49    compaq    COMPAQ    PageOpen    LicenseDialog
2014/10/26:10:44:54    compaq    COMPAQ    PageOpen    ProductInfoDialog
2014/10/26:10:45:23    compaq    COMPAQ    PageOpen    ProductSelectionDialog2
2014/10/26:10:45:39    compaq    COMPAQ    PageOpen    FullProgressDialog
2014/10/26:10:45:40    compaq    COMPAQ    Installing Microsoft Visual C++ 2005 Redistributable (x86): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2005SP1ATL\vcredist_x86.exe" /q:a /T:C:\Windows\temp /c:"VCREDI~3.EXE /q:a /c:""msiexec /i vcredist.msi /qn /l*v C:\Users\compaq\AppData\Local\Temp\vcredist_x86_2005.log"" "
2014/10/26:10:46:21    compaq    COMPAQ    Install    Microsoft Visual C++ 2005 Redistributable (x86)    Succeeded
2014/10/26:10:46:21    compaq    COMPAQ    Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/10/26:10:46:24    compaq    COMPAQ    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/10/26:10:46:24    compaq    COMPAQ    Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/10/26:10:46:25    compaq    COMPAQ    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/10/26:10:46:25    compaq    COMPAQ    Installing DirectX® Runtime: "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/26:10:46:53    compaq    COMPAQ    Install    DirectX® Runtime    Succeeded
2014/10/26:10:46:53    compaq    COMPAQ    Installing Autodesk® Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:10:49:06    compaq    COMPAQ    Install    Autodesk® Material Library 2015    Succeeded
2014/10/26:10:49:17    compaq    COMPAQ    Installing Autodesk® Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:10:50:27    compaq    COMPAQ    Install    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2014/10/26:10:50:27    compaq    COMPAQ    Installing Autodesk® Material Library 2015 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:10:51:55    compaq    COMPAQ    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2014/10/26:10:52:12    compaq    COMPAQ    Installing Autodesk® 3ds Max 2015:  TRANSFORMS="C:\Users\compaq\AppData\Local\Temp\_AIE57E.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" INSTALLDIR="E:\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:11:23:22    compaq    COMPAQ    Install    Autodesk® 3ds Max 2015    Succeeded
2014/10/26:11:23:23    compaq    COMPAQ    Installing Autodesk® Populate Data for 3ds Max 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:11:36:59    compaq    COMPAQ    Install    Autodesk® Populate Data for 3ds Max 2015    Succeeded
2014/10/26:11:36:59    compaq    COMPAQ    Installing Autodesk® 3ds Max 2015 SP1: "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\x64\Patch\3dsMax2015_SP1.exe" /q
2014/10/26:11:42:46    compaq    COMPAQ    Install    Autodesk® 3ds Max 2015 SP1    Failed    Failure is ignored, Result=1603
2014/10/26:11:42:47    compaq    COMPAQ    Installing Autodesk® Backburner 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:11:43:02    compaq    COMPAQ    Install    Autodesk® Backburner 2015    Succeeded
2014/10/26:11:43:03    compaq    COMPAQ    Installing Autodesk® DirectConnect 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;Autodesk® DirectConnect 2015 HF1,;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:11:46:57    compaq    COMPAQ    Install    Autodesk® DirectConnect 2015    Succeeded
2014/10/26:11:47:24    compaq    COMPAQ    Install    Autodesk® DirectConnect 2015 HF1    Succeeded
2014/10/26:11:47:25    compaq    COMPAQ    Installing Autodesk® Inventor Server Engine For 3ds Max 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;Autodesk® Inventor Server Engine For 3ds Max 2015 SP1,;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:11:48:42    compaq    COMPAQ    Install    Autodesk® Inventor Server Engine For 3ds Max 2015    Succeeded
2014/10/26:11:49:05    compaq    COMPAQ    Install    Autodesk® Inventor Server Engine For 3ds Max 2015 SP1    Succeeded
2014/10/26:11:49:05    compaq    COMPAQ    Installing Autodesk® Revit® 2015 Interoperability for Autodesk® 3ds Max and 3ds Max Design 2015:  C_APP_NAME=3dsMax C_APP_VER=2015 C_RES=ENU RX_CF="Revit Interoperability 2015" ADDLOCAL=RevitEngine,RPC,MACRO INSTALLDIR="E:\Autodesk\"  ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES=";;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:11:51:26    compaq    COMPAQ    Install    Autodesk® Revit® 2015 Interoperability for Autodesk® 3ds Max and 3ds Max Design 2015    Succeeded
2014/10/26:11:51:43    compaq    COMPAQ    PageOpen    InstallCompleteDialog
2014/10/26:12:00:13    compaq    COMPAQ    === Setup ended ===
2014/10/26:14:02:50    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/26:14:02:50    compaq    COMPAQ    Path_Length: 148
2014/10/26:14:02:50    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AIAFD2.tmp
2014/10/26:14:02:50    compaq    COMPAQ    Launch
2014/10/26:14:03:28    compaq    COMPAQ    PageOpen    LaunchDialog
2014/10/26:14:02:44    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/26:14:02:44    compaq    COMPAQ    Path_Length: 148
2014/10/26:14:02:44    compaq    COMPAQ    Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/10/26:14:02:44    compaq    COMPAQ    Launch
2014/10/26:14:02:44    compaq    COMPAQ    CommandLine
2014/10/26:14:02:44    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AIAFD2.tmp
2014/10/26:14:03:35    compaq    COMPAQ    === Setup ended ===
2014/10/26:14:03:36    compaq    COMPAQ    PageOpen    ProductInfoDialog
2014/10/26:14:06:06    compaq    COMPAQ    PageOpen    ProductSelectionDialog2
2014/10/26:14:06:43    compaq    COMPAQ    PageOpen    ProductInfoDialog
2014/10/26:14:06:50    compaq    COMPAQ    === Setup ended ===
2014/10/26:14:12:03    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/26:14:12:03    compaq    COMPAQ    Launch
2014/10/26:14:12:03    compaq    COMPAQ    CommandLine    /P {52B37EC7-D836-0410-0264-3C24BCED2010} /M MAX /LANG en-us
2014/10/26:14:12:32    compaq    COMPAQ    === Setup ended ===
2014/10/26:14:12:14    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/26:14:12:14    compaq    COMPAQ    Launch
2014/10/26:14:12:33    compaq    COMPAQ    PageOpen    MaintenanceDialog
2014/10/26:14:18:12    compaq    COMPAQ    PageOpen    RepairDialog
2014/10/26:14:20:23    compaq    COMPAQ    PageOpen    MaintenanceDialog
2014/10/26:14:20:25    compaq    COMPAQ    PageOpen    MaintVerifyReadyDialog
2014/10/26:14:20:28    compaq    COMPAQ    PageOpen    FullProgressDialog
2014/10/26:14:20:47    compaq    COMPAQ    Installing Autodesk® 3ds Max 2015:  REMOVE=ALL INSTALLDIR="E:\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:14:20:57    compaq    COMPAQ    Uninstall    Autodesk® 3ds Max 2015    Failed    Installation aborted, Result=1602
2014/10/26:14:20:58    compaq    COMPAQ    PageOpen    MaintFailedDialog
2014/10/26:14:21:21    compaq    COMPAQ    === Setup ended ===
2014/10/26:14:36:25    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/26:14:36:25    compaq    COMPAQ    Path_Length: 148
2014/10/26:14:36:25    compaq    COMPAQ    Current Directory E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm
2014/10/26:14:36:25    compaq    COMPAQ    Launch
2014/10/26:14:36:25    compaq    COMPAQ    CommandLine
2014/10/26:14:36:25    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AI88F2.tmp
2014/10/26:14:36:46    compaq    COMPAQ    === Setup ended ===
2014/10/26:14:36:32    compaq    COMPAQ    === Setup started on COMPAQ by compaq ===
2014/10/26:14:36:32    compaq    COMPAQ    Path_Length: 148
2014/10/26:14:36:32    compaq    COMPAQ    Current Directory C:\Users\compaq\AppData\Local\Temp\_AI88F2.tmp
2014/10/26:14:36:32    compaq    COMPAQ    Launch
2014/10/26:14:36:44    compaq    COMPAQ    PageOpen    LaunchDialog
2014/10/26:14:41:44    compaq    COMPAQ    PageOpen    LicenseDialog
2014/10/26:14:41:48    compaq    COMPAQ    PageOpen    ProductInfoDialog
2014/10/26:14:42:07    compaq    COMPAQ    PageOpen    ProductSelectionDialog2
2014/10/26:14:42:22    compaq    COMPAQ    PageOpen    FullProgressDialog
2014/10/26:14:43:08    compaq    COMPAQ    Installing Microsoft Visual C++ 2012 Redistributable (x86): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x86\VCRedist\2012\vcredist_x86.exe" /install /quiet /norestart
2014/10/26:14:43:11    compaq    COMPAQ    Install    Microsoft Visual C++ 2012 Redistributable (x86)    Succeeded
2014/10/26:14:43:11    compaq    COMPAQ    Installing Microsoft Visual C++ 2012 Redistributable (x64): "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\x64\VCRedist\2012\vcredist_x64.exe" /install /quiet /norestart
2014/10/26:14:43:12    compaq    COMPAQ    Install    Microsoft Visual C++ 2012 Redistributable (x64)    Succeeded
2014/10/26:14:43:12    compaq    COMPAQ    Installing DirectX® Runtime: "E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\3rdParty\DirectX\DXSETUP.exe" /silent
2014/10/26:14:43:40    compaq    COMPAQ    Install    DirectX® Runtime    Succeeded
2014/10/26:14:43:40    compaq    COMPAQ    Installing Autodesk® Material Library 2015:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:14:45:00    compaq    COMPAQ    Install    Autodesk® Material Library 2015    Succeeded
2014/10/26:14:45:01    compaq    COMPAQ    Installing Autodesk® Material Library 2015 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:14:45:35    compaq    COMPAQ    Install    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2014/10/26:14:45:35    compaq    COMPAQ    Installing Autodesk® Material Library 2015 - Medium Resolution Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2015" SETUP_PACKAGECODE={8E850B3E-B21A-4790-0264-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{427F733F-4D6C-45BC-9324-EB743104C321},;;;;" ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:14:47:04    compaq    COMPAQ    Install    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2014/10/26:14:47:21    compaq    COMPAQ    Installing Autodesk® 3ds Max 2015:  TRANSFORMS="C:\Users\compaq\AppData\Local\Temp\_AI88F2.tmp\x64\max\3dsMax-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="E:\Autodesk\Autodesk_3ds_Max_2015_EFGJKS_Win_64bit_R2_dlm\" INSTALLDIR="E:\Autodesk\3ds Max 2015\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
 2014/10/26:15:12:57    compaq    COMPAQ    Install    Autodesk® 3ds Max 2015    Failed    Installation aborted, Result=1603
2014/10/26:15:13:14    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015 - Medium Resolution Library    Succeeded
2014/10/26:15:13:19    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015 - Base Image Library    Succeeded
2014/10/26:15:13:42    compaq    COMPAQ    Rollback    Autodesk® Material Library 2015    Succeeded
2014/10/26:15:13:42    compaq    COMPAQ    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2014/10/26:15:13:42    compaq    COMPAQ    Rollback    Microsoft Visual C++ 2012 Redistributable (x64)    Failed    Failure is ignored, Result=1619
2014/10/26:15:13:42    compaq    COMPAQ    Rollback    Microsoft Visual C++ 2012 Redistributable (x86)    Failed    Failure is ignored, Result=1619
1 REPLY 1
dembkod
in reply to: x3ask
x3ask
I am sorry to say, this can be a bad one. You have corrupt registry keys that have permissions stripped. If you navigate to the registry key and check permissions you can try to add them. The problem is, after you add the permissions, assuming you can add the permissions, the next time you run the installer, the error may appear again but for a different key. This could theoretically be on a hundred keys.
The time it takes to manually change these keys may be better served repairing or reinstalling Windows. This would certainly rebuild the registry to default.
I have a post with this error:
http://knowledge.autodesk.com/support/inventor-products/troubleshooting/caas/sfdcarticles/sfdcarticl...
This may take a long time to troubleshoot and you may never get a good solution. If you have the ability to reformat your machine quickly- some organizations can do this pretty fast, this may be your quickest solution as opposed to HOURS of tweaking reg keys.
Thank you for taking part in our community!
David Dembkoski
Administrator Productivity
