So I've created the deployment for max 2015 but when it gets to installing extension 1 it involves user interaction. The point of having the deployment is for no interaction and I was wondering if anyone knew and flags to put in th parameters to run it silently. Right now I get the accept EULA and actually having to hit install. Any ideas?
As promissed, i said i would inform you once i was in the office on how to install Extension 1 for 3DS Max silently. Unfortunately i didnt do this for 3DS Max, it was for 3DS Max Design but im hoping you can do the same.
The way i did it was to use the Extension *.MSI.
If you download the Extension *.Exe and Run it, you should see an Image after the License Agreement and on the bottom left of the Image there is a "Deploy" button. Select this and chose a folder to extract SP2 and the Extension.
Once you browse to this location, there should hopefully be an *.MSI for the Extension. Use this in your Deployment and utilise /qb to install with a basic UI.
Hope that helps!
