Installation & Licensing
Welcome to Autodeskā€™s Installation and Licensing Forums. Share your knowledge, ask questions, and explore popular Download, Installation, and Licensing topics.
Showing results forĀ
ShowĀ Ā onlyĀ  | Search instead forĀ
Did you mean:Ā
704 Views, 2 Replies
3DS MAX 2015 ERROR
first I want to thank you for providing the free version for students. I installed the 3dsmax 2015 64bit on my laptop while processing the instalation there was the Error: "adlmPITSetProductInformation failed" and I had to uninstall and install back again to fix this problem. the software was installed after all, however now that I want to open the program for the first time after it's installation it gives another error message saying " the software license checkout failed" error41
getting this software to be honest got my whole day and now I have no idea how to fix this error can you plz help me somehow, I really need it for my new semester
thank you in advance
best regards
2 REPLIES 2
TravisNave
You might start here:
http://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/Error-a...
Good Luck!
Travis Nave Send TravisNave a Private Message                                             Need help in your post? Mention me with @TravisNave
My Expert Contributions to the
Autodesk Forums:
FLEXnet License Admin | MSI Cleanup Utility | .NET Framework Cleanup Tool | IPv6 NLM Fix | adskflex.opt Options File | Combine .LIC Files
Hello Travis,
Thank you for the reply however this was not my question.as I mentioned I already fixed the adlmpit error and reinstalled the software the problem is that now it doesn't open the program due to a new error "the software license checkout failed" error41
Can you plz suggest any solution so that I can use the program
Thank you in advance
Best regards
Administrator Productivity
