Installation & Licensing
3DS Max 2014 Installer - Failed Internet Connection
2 REPLIES 2
3706 Views, 2 Replies
I am trying to install 3DS Max now for about 4 hours, but it won't work.
Everytime the installer stops when installing .Network 3.5 SP1. I already cleared my computer off all .Net programms. The installer then installs .Net 4.0 but stops again when starting to install 3.5.
Install log cann be seen here.
http://pastebin.com/qg6R99dA
Few things:
- UAC is disabled
- Firewall is disabled
- Anti-Virus programm (MSE) is disabled
- Checked Ports and everything - seems all fine.
2 REPLIES 2
dembkod
phoenix100,
Hello. You can try a few things:
Comment out the setup.ini file by opening it in note pad and searching for all instances of PREREQUISITES and replacing with #PREREQUISITES. Save the file and run the installer. This will avoid installing the prerequisites and you may need to manually install them after (from the 3rd party folder)
Past this, I would run the NET cleanup tool and retry
http://blogs.msdn.com/b/astebner/archive/2008/08/28/8904493.aspx
Thank you for taking part in our community!
David Dembkoski
Hello, i've same problem like this in the past
So, u need to try this..
From ur installer folder find setup.ini , then delete this
;DOTNET45;_DOTNET35SP1 #1
#============= DOTNET Begin ===============
[DOTNET45]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.5
EXE_PATH=3rdParty\NET\45\wcu\dotNetFramework\dotnetfx45_full_x86_x64.exe
EXE_PARAM=/q /norestart
VC_FUNC=DotnetVerify
VC_SOURCE=Setup\SetupUi.dll
VC_PARAM=.NET Framework 4.5
VC_DESCRIPTION=Detecting .NET 4.5 Runtime
DISKCOST=352037424
[_DOTNET35SP1]
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 3.5 SP1
EXE_PATH=3rdParty\NET\35SP1\wcu\dotNetFramework\Install35Net.exe
VC_SOURCE=Setup\SetupUI.dll
VC_PARAM=.NET Framework 3.5 SP1
IGNORE_FAILURE=NO
VC_DESCRIPTION=Detecting .NET Runtime 3.5 SP1
DISKCOST=80000000
[DOTNET]
#== This section is required by the framework to display a package level alert_
#== _if the system does not contain a minimum version of NET (set in VC_PARAM below)
PLATFORM=ALL
PRODUCT_NAME=.NET Framework Runtime 4.0
EXE_PATH=3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe
VC_PARAM=4.0.30319
VC_DESCRIPTION=Detecting .NET 4.0 Runtime
#============= DOTNET End ===============
Hope u can fix that.
Administrator Productivity
