Installation & Licensing
3ds Max 2014 installation Failed
4 REPLIES 4
RealismFreak
6445 Views, 4 Replies
 I can't because I can't download 3ds max 2014 whenever I try it just goes to medium image and It fails I have the bug text file  If it's needed and also sometimes I have communication failure but sometimes the main problem is can't even start using 3ds max... so here's the bug text file:
2014/1/14:16:42:13 Svetlana SVETLANA === Setup started on SVETLANA by Svetlana ===
2014/1/14:16:42:13 Svetlana SVETLANA Path_Length: 151
2014/1/14:16:42:13 Svetlana SVETLANA Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit  _wi_en-US
2014/1/14:16:42:13 Svetlana SVETLANA Launch
2014/1/14:16:42:13 Svetlana SVETLANA CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US_... /akamai /auth authparam /sid SESSION_ID
2014/1/14:16:42:13 Svetlana SVETLANA Current Directory C:\Users\Svetlana\AppData\Local\Temp\_AIBE70.tmp
2014/1/14:17:08:56 Svetlana SVETLANA === Setup ended ===
2014/1/14:16:42:19 Svetlana SVETLANA === Setup started on SVETLANA by Svetlana ===
2014/1/14:16:42:19 Svetlana SVETLANA Path_Length: 151
2014/1/14:16:42:19 Svetlana SVETLANA Current Directory C:\Users\Svetlana\AppData\Local\Temp\_AIBE70.tmp
2014/1/14:16:42:19 Svetlana SVETLANA Launch
2014/1/14:17:03:26 Svetlana SVETLANA Download Error Network error SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3...n-US_Setup.exe
2014/1/14:17:03:26 Svetlana SVETLANA Error downloading. Please Install Now again from the Autodesk website. 2014/1/14:17:09:00 Svetlana SVETLANA === Setup ended ===
2014/1/14:17:22:04 Svetlana SVETLANA === Setup started on SVETLANA by Svetlana ===
2014/1/14:17:22:04 Svetlana SVETLANA Path_Length: 151
2014/1/14:17:22:04 Svetlana SVETLANA Current Directory C:\Users\Svetlana\AppData\Local\Temp\_AI2161.tmp
2014/1/14:17:22:04 Svetlana SVETLANA Launch
2014/1/14:17:43:12 Svetlana SVETLANA Download Error Network error SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3...n-US_Setup.exe
2014/1/14:17:43:12 Svetlana SVETLANA Error downloading. Please Install Now again from the Autodesk website. 2014/1/14:17:44:28 Svetlana SVETLANA === Setup ended ===
2014/1/14:17:21:58 Svetlana SVETLANA === Setup started on SVETLANA by Svetlana ===
2014/1/14:17:21:58 Svetlana SVETLANA Path_Length: 151
2014/1/14:17:21:58 Svetlana SVETLANA Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit  _wi_en-US
2014/1/14:17:21:58 Svetlana SVETLANA Launch
2014/1/14:17:21:58 Svetlana SVETLANA CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US_... /akamai /auth authparam /sid SESSION_ID
2014/1/14:17:21:58 Svetlana SVETLANA Current Directory C:\Users\Svetlana\AppData\Local\Temp\_AI2161.tmp
2014/1/27:01:23:29 Svetlana SVETLANA === Setup started on SVETLANA by Svetlana ===
2014/1/27:01:23:29 Svetlana SVETLANA Path_Length: 151
2014/1/27:01:23:29 Svetlana SVETLANA Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit  _wi_en-US
2014/1/27:01:23:29 Svetlana SVETLANA Launch
2014/1/27:01:23:29 Svetlana SVETLANA CommandLine /url "http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US_... /akamai /auth authparam /sid SESSION_ID
2014/1/27:01:23:29 Svetlana SVETLANA Current Directory C:\Users\Svetlana\AppData\Local\Temp\_AIB835.tmp
2014/1/27:01:23:42 Svetlana SVETLANA === Setup ended ===
2014/1/27:01:23:32 Svetlana SVETLANA === Setup started on SVETLANA by Svetlana ===
2014/1/27:01:23:32 Svetlana SVETLANA Path_Length: 151
2014/1/27:01:23:32 Svetlana SVETLANA Current Directory C:\Users\Svetlana\AppData\Local\Temp\_AIB835.tmp
2014/1/27:01:23:32 Svetlana SVETLANA Launch
2014/1/27:01:23:40 Svetlana SVETLANA Download Skipped SETUP_CONFIG http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x64...
2014/1/27:01:23:42 Svetlana SVETLANA PageOpen LaunchDialog
2014/1/27:01:23:55 Svetlana SVETLANA PageOpen LicenseDialog
2014/1/27:01:24:24 Svetlana SVETLANA PageOpen ProductInfoDialog
2014/1/27:01:26:13 Svetlana SVETLANA PageOpen ProductSelectionDialog2
2014/1/27:01:26:39 Svetlana SVETLANA PageOpen FullProgressDialog
2014/1/27:01:26:39 Svetlana SVETLANA Download Skipped DIRECTX http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX.t...
2014/1/27:01:26:39 Svetlana SVETLANA Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2014/1/27:01:28:22 Svetlana SVETLANA Install DirectX® Runtime Succeeded
2014/1/27:01:28:22 Svetlana SVETLANA Download Skipped CM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CM.tar.lz...
2014/1/27:01:28:22 Svetlana SVETLANA Installing Autodesk® Material Library 2014:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/27:01:29:17 Svetlana SVETLANA Install Autodesk® Material Library 2014 Succeeded
2014/1/27:01:29:18 Svetlana SVETLANA Download Skipped CMILB http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILB.tar...
2014/1/27:01:29:18 Svetlana SVETLANA Installing Autodesk® Material Library 2014 - Base Image Library:   ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2014/1/27:01:30:49 Svetlana SVETLANA Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/1/27:01:30:50 Svetlana SVETLANA Download Play CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.tar...
2014/1/27:01:56:24 Svetlana SVETLANA Download Aborted CMILM http://trial2.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.tar...
2014/1/27:01:56:25 Svetlana SVETLANA Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2014/1/27:01:57:04 Svetlana SVETLANA Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2014/1/27:01:58:13 Svetlana SVETLANA Rollback Autodesk® Material Library 2014 Succeeded
2014/1/27:01:58:13 Svetlana SVETLANA Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
PS: please reply quickly as possible Im having this problem for a month now...
4 REPLIES 4
TravisNave
in reply to: RealismFreak
This issue has plagued a lot of users.
See my article here on a work-around that has had much success:
http://forums.autodesk.com/t5/Installation-Licensing/Download-Failed-Installation-aborted-Result-160...
Good Luck!
Autodesk Forums:
i might have the solution, install DotNet_win 8 or DotNet_win 8.1 or whatever your os. its worked for me. cheers
Mr_Vader
in reply to: TravisNave
Here is the Installation log, please help
2016/1/10:14:06:45 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/10:14:06:45 Elijah ELIJAHSPC Path_Length: 151
2016/1/10:14:06:45 Elijah ELIJAHSPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2016/1/10:14:06:45 Elijah ELIJAHSPC Launch
2016/1/10:14:06:45 Elijah ELIJAHSPC CommandLine /PK 128F1 /SN 900-67167239 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-U...
2016/1/10:14:06:45 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AI1062.tmp
2016/1/10:14:08:39 Elijah ELIJAHSPC === Setup ended ===
2016/1/10:14:06:58 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/10:14:06:58 Elijah ELIJAHSPC Path_Length: 151
2016/1/10:14:06:58 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AI1062.tmp
2016/1/10:14:06:58 Elijah ELIJAHSPC Launch
2016/1/10:14:08:15 Elijah ELIJAHSPC Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/10:14:08:35 Elijah ELIJAHSPC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/10:14:08:39 Elijah ELIJAHSPC PageOpen LaunchDialog
2016/1/10:14:13:36 Elijah ELIJAHSPC PageOpen LicenseDialog
2016/1/10:14:13:36 Elijah ELIJAHSPC PageOpen ProductInfoDialog
2016/1/10:14:13:36 Elijah ELIJAHSPC PageOpen ProductSelectionDialog2
2016/1/10:14:13:55 Elijah ELIJAHSPC PageOpen FullProgressDialog
2016/1/10:14:13:57 Elijah ELIJAHSPC Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX...
2016/1/10:14:16:00 Elijah ELIJAHSPC Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX...
2016/1/10:14:16:00 Elijah ELIJAHSPC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2016/1/10:14:24:30 Elijah ELIJAHSPC === Setup ended ===
2016/1/10:14:29:05 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/10:14:29:05 Elijah ELIJAHSPC Path_Length: 151
2016/1/10:14:29:05 Elijah ELIJAHSPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2016/1/10:14:29:05 Elijah ELIJAHSPC Launch
2016/1/10:14:29:05 Elijah ELIJAHSPC CommandLine /PK 128F1 /SN 900-67167239 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-U...
2016/1/10:14:29:05 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AI86CA.tmp
2016/1/10:14:29:15 Elijah ELIJAHSPC === Setup ended ===
2016/1/10:14:29:11 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/10:14:29:11 Elijah ELIJAHSPC Path_Length: 151
2016/1/10:14:29:11 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AI86CA.tmp
2016/1/10:14:29:11 Elijah ELIJAHSPC Launch
2016/1/10:14:29:13 Elijah ELIJAHSPC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/10:14:29:14 Elijah ELIJAHSPC PageOpen LaunchDialog
2016/1/10:14:29:26 Elijah ELIJAHSPC PageOpen LicenseDialog
2016/1/10:14:29:26 Elijah ELIJAHSPC PageOpen ProductInfoDialog
2016/1/10:14:29:26 Elijah ELIJAHSPC PageOpen ProductSelectionDialog2
2016/1/10:14:29:31 Elijah ELIJAHSPC PageOpen FullProgressDialog
2016/1/10:14:29:31 Elijah ELIJAHSPC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX...
2016/1/10:14:29:31 Elijah ELIJAHSPC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2016/1/10:14:31:27 Elijah ELIJAHSPC Install DirectX® Runtime Succeeded
2016/1/10:14:31:28 Elijah ELIJAHSPC Download Play CM http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CM.tar....
2016/1/10:14:32:20 Elijah ELIJAHSPC Download Complete CM http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CM.tar....
2016/1/10:14:32:20 Elijah ELIJAHSPC Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/10:14:33:27 Elijah ELIJAHSPC Install Autodesk® Material Library 2014 Succeeded
2016/1/10:14:33:27 Elijah ELIJAHSPC Download Play CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILB.t...
2016/1/10:14:34:31 Elijah ELIJAHSPC Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILB.t...
2016/1/10:14:34:31 Elijah ELIJAHSPC Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/10:14:35:10 Elijah ELIJAHSPC Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2016/1/10:14:35:11 Elijah ELIJAHSPC Download Play CMILM http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.t...
2016/1/10:14:47:22 Elijah ELIJAHSPC Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.t...
2016/1/10:14:47:22 Elijah ELIJAHSPC Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/1/10:14:48:39 Elijah ELIJAHSPC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2016/1/10:14:50:09 Elijah ELIJAHSPC Rollback Autodesk® Material Library 2014 Succeeded
2016/1/10:14:50:09 Elijah ELIJAHSPC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
2016/1/10:14:50:10 Elijah ELIJAHSPC PageOpen InstallCompleteDialog
2016/1/10:14:50:53 Elijah ELIJAHSPC === Setup ended ===
2016/1/11:14:52:11 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/11:14:52:11 Elijah ELIJAHSPC Path_Length: 151
2016/1/11:14:52:11 Elijah ELIJAHSPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2016/1/11:14:52:11 Elijah ELIJAHSPC Launch
2016/1/11:14:52:11 Elijah ELIJAHSPC CommandLine /PK 128F1 /SN 900-67167239 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-U...
2016/1/11:14:52:11 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AIA92E.tmp
2016/1/11:14:53:25 Elijah ELIJAHSPC === Setup ended ===
2016/1/11:14:52:21 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/11:14:52:21 Elijah ELIJAHSPC Path_Length: 151
2016/1/11:14:52:21 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AIA92E.tmp
2016/1/11:14:52:21 Elijah ELIJAHSPC Launch
2016/1/11:14:53:13 Elijah ELIJAHSPC Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/11:14:53:24 Elijah ELIJAHSPC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/11:14:53:25 Elijah ELIJAHSPC PageOpen LaunchDialog
2016/1/11:15:00:06 Elijah ELIJAHSPC PageOpen LicenseDialog
2016/1/11:15:00:06 Elijah ELIJAHSPC PageOpen ProductInfoDialog
2016/1/11:15:00:06 Elijah ELIJAHSPC PageOpen ProductSelectionDialog2
2016/1/11:15:00:14 Elijah ELIJAHSPC PageOpen FullProgressDialog
2016/1/11:15:00:15 Elijah ELIJAHSPC Download Play DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX...
2016/1/11:15:00:49 Elijah ELIJAHSPC Download Complete DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX...
2016/1/11:15:00:49 Elijah ELIJAHSPC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2016/1/11:15:29:30 Elijah ELIJAHSPC === Setup ended ===
2016/1/14:14:12:01 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/14:14:12:01 Elijah ELIJAHSPC Path_Length: 151
2016/1/14:14:12:01 Elijah ELIJAHSPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2016/1/14:14:12:01 Elijah ELIJAHSPC Launch
2016/1/14:14:12:01 Elijah ELIJAHSPC CommandLine /PK 128F1 /SN 900-67167239 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-U...
2016/1/14:14:12:01 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AIB3C8.tmp
2016/1/14:14:13:27 Elijah ELIJAHSPC === Setup ended ===
2016/1/14:14:12:07 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/14:14:12:07 Elijah ELIJAHSPC Path_Length: 151
2016/1/14:14:12:07 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AIB3C8.tmp
2016/1/14:14:12:07 Elijah ELIJAHSPC Launch
2016/1/14:14:13:09 Elijah ELIJAHSPC Download Play SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/14:14:13:25 Elijah ELIJAHSPC Download Complete SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/14:14:13:26 Elijah ELIJAHSPC PageOpen LaunchDialog
2016/1/14:14:14:07 Elijah ELIJAHSPC PageOpen LicenseDialog
2016/1/14:14:14:07 Elijah ELIJAHSPC PageOpen ProductSelectionDialog2
2016/1/14:14:14:24 Elijah ELIJAHSPC PageOpen FullProgressDialog
2016/1/14:14:14:25 Elijah ELIJAHSPC Installing Autodesk® 3ds Max 2014 SDK: TRANSFORMS="C:\Users\Elijah\AppData\Local\Temp\_AIB3C8.tmp\x64\Tools\MAXSDK\SDK_3DSMAX2014-standalone.mst" ADSK_EULA_STATUS=#1 ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2014 SDK\maxsdk\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/14:14:16:19 Elijah ELIJAHSPC Install Autodesk® 3ds Max 2014 SDK Succeeded
2016/1/14:14:16:20 Elijah ELIJAHSPC PageOpen InstallCompleteDialog
2016/1/14:14:16:29 Elijah ELIJAHSPC === Setup ended ===
2016/1/14:14:16:55 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/14:14:16:55 Elijah ELIJAHSPC Path_Length: 151
2016/1/14:14:16:55 Elijah ELIJAHSPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2016/1/14:14:16:55 Elijah ELIJAHSPC Launch
2016/1/14:14:16:55 Elijah ELIJAHSPC CommandLine /PK 128F1 /SN 900-67167239 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-U...
2016/1/14:14:16:55 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AI30D4.tmp
2016/1/14:14:17:02 Elijah ELIJAHSPC === Setup ended ===
2016/1/14:14:17:00 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/14:14:17:00 Elijah ELIJAHSPC Path_Length: 151
2016/1/14:14:17:00 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AI30D4.tmp
2016/1/14:14:17:00 Elijah ELIJAHSPC Launch
2016/1/14:14:17:01 Elijah ELIJAHSPC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/14:14:17:02 Elijah ELIJAHSPC PageOpen LaunchDialog
2016/1/14:14:17:32 Elijah ELIJAHSPC PageOpen LicenseDialog
2016/1/14:14:17:32 Elijah ELIJAHSPC PageOpen ProductSelectionDialog2
2016/1/14:14:17:34 Elijah ELIJAHSPC PageOpen LicenseDialog
2016/1/14:14:17:34 Elijah ELIJAHSPC PageOpen LaunchDialog
2016/1/14:14:42:09 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/14:14:42:09 Elijah ELIJAHSPC Path_Length: 151
2016/1/14:14:42:09 Elijah ELIJAHSPC Current Directory C:\Autodesk\Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-US
2016/1/14:14:42:09 Elijah ELIJAHSPC Launch
2016/1/14:14:42:09 Elijah ELIJAHSPC CommandLine /PK 128F1 /SN 900-67167239 /akamai /sid SESSION_ID /skipEULA /student /url "http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/Autodesk_3ds_Max_2014_EFGJKS_Win_64bit_wi_en-U...
2016/1/14:14:42:09 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AI4598.tmp
2016/1/14:14:44:04 Elijah ELIJAHSPC === Setup ended ===
2016/1/14:14:42:22 Elijah ELIJAHSPC === Setup started on ELIJAHSPC by Elijah ===
2016/1/14:14:42:22 Elijah ELIJAHSPC Path_Length: 151
2016/1/14:14:42:22 Elijah ELIJAHSPC Current Directory C:\Users\Elijah\AppData\Local\Temp\_AI4598.tmp
2016/1/14:14:42:22 Elijah ELIJAHSPC Launch
2016/1/14:14:44:00 Elijah ELIJAHSPC Download Skipped SETUP_CONFIG http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/SETUP_x...
2016/1/14:14:44:04 Elijah ELIJAHSPC PageOpen LaunchDialog
2016/1/14:14:44:18 Elijah ELIJAHSPC PageOpen LicenseDialog
2016/1/14:14:44:19 Elijah ELIJAHSPC PageOpen ProductInfoDialog
2016/1/14:14:44:19 Elijah ELIJAHSPC PageOpen ProductSelectionDialog2
2016/1/14:14:46:18 Elijah ELIJAHSPC PageOpen FullProgressDialog
2016/1/14:14:46:18 Elijah ELIJAHSPC Download Skipped DIRECTX http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/DIRECTX...
2016/1/14:14:46:18 Elijah ELIJAHSPC Installing DirectX® Runtime: "C:\Autodesk\WI\Autodesk 3ds Max 2014\3rdParty\DirectX\DXSETUP.exe" /silent
2016/1/14:14:50:04 Elijah ELIJAHSPC Install DirectX® Runtime Succeeded
2016/1/14:14:50:05 Elijah ELIJAHSPC Download Play CM http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CM.tar....
2016/1/14:14:50:08 Elijah ELIJAHSPC Download Complete CM http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CM.tar....
2016/1/14:14:50:09 Elijah ELIJAHSPC Installing Autodesk® Material Library 2014: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="Microsoft Visual C++ 2008 SP1 Redistributable (x86),;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/14:14:51:32 Elijah ELIJAHSPC Install Autodesk® Material Library 2014 Succeeded
2016/1/14:14:51:33 Elijah ELIJAHSPC Download Play CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILB.t...
2016/1/14:14:52:08 Elijah ELIJAHSPC Download Complete CMILB http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILB.t...
2016/1/14:14:52:08 Elijah ELIJAHSPC Installing Autodesk® Material Library 2014 - Base Image Library: ADSK_EULA_STATUS=#1 MUILANG=en-us SETUP_PACKAGENAME="Autodesk 3ds Max 2014" SETUP_PACKAGECODE={8E850B3E-B21A-4780-0064-7CCB73BD8B3B} SETUP_UNINSTALLKEYS=1 SETUP_ISLANGUAGEPACK=0 SETUP_PRODUCTDEPENDENCIES="{644F9B19-A462-499C-BF4D-300ABC2A28B1},;;;" ADSK_SOURCE_ROOT="C:\Autodesk\WI\Autodesk 3ds Max 2014" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2016/1/14:14:52:49 Elijah ELIJAHSPC Install Autodesk® Material Library 2014 - Base Image Library Succeeded
2016/1/14:14:52:52 Elijah ELIJAHSPC Download Play CMILM http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.t...
2016/1/14:14:56:56 Elijah ELIJAHSPC Download Aborted CMILM http://edutrial.autodesk.com/SWDLDNET3/2014/3DSMAX/WI/{CE0ABC82-BD3C-4F3D-9370-6CEBA82D6532}/CMILM.t...
2016/1/14:14:56:56 Elijah ELIJAHSPC Install Autodesk® Material Library 2014 - Medium Resolution Library Failed Download Failed, Installation aborted, Result=1603
2016/1/14:15:50:48 Elijah ELIJAHSPC Rollback Autodesk® Material Library 2014 - Base Image Library Succeeded
2016/1/14:15:52:36 Elijah ELIJAHSPC Rollback Autodesk® Material Library 2014 Succeeded
2016/1/14:15:52:36 Elijah ELIJAHSPC Rollback DirectX® Runtime Failed Failure is ignored, Result=1619
TravisNave
in reply to: Mr_Vader
Download your 2014 version of the library here and install it first.
https://knowledge.autodesk.com/support/autocad/troubleshooting/caas/sfdcarticles/sfdcarticles/How-to...
Good Luck!
Autodesk Forums:
Administrator Productivity
