Installation & Licensing
3ds Max 2014 Crashes On Startup
10 REPLIES 10
Message 1 of 11
9944 Views, 10 Replies
I have downloaed 3ds Max 2014, but it crashes on startup after saying that it is trying to verify my license. I have a student licence and my product key was entered successfully when I downloaded the programme. Please see the image attached for ore details on the error message.
I have installed both of the available serivce packs, unfortunatley neither made any difference.
I have also tried edditing the "adskflex_*_tsf".data file as suggested (http://forums.autodesk.com/t5/Installation-Licensing/Autodesk-component-has-stopped-working/td-p/384...).
I'm working from an ACER Aspire laptop, with an NVIDEA GEFORCE GT 540M graphics card, an intel i7 processor, 8gb RAM and 30GB space free on my HDD.
I'd really apprciate any help fixing this issue as I need 3ds Max for my work.
Many thanks,
Mark
10 REPLIES 10
Message 2 of 11
TravisNave
Welcome to the Community.
This could be the 2014 Activation Crash issue.  You might check that out and see if it fixes your issue.
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=21825687&linkID=12305695
Autodesk Forums:
Message 3 of 11
pmaloney5
I too have this exact problem and have been going back and forth with tech support via email with no success. Have attemped both 3ds Max 2014 and 3ds Max Design 2014 with the EXACT same problem. All video drivers are up to date. AutoCAD 2014 installed fine.
If anyone has a solution for this, I would REALLY appreciate it! I'm starting to fear incompatible video card.
Thanks!
My system is:
DELL XPS 15 - Windows 8 Pro 64 bit
Processor - QuadCore i7-3612QM CPU @ 2.10GHz
HDD - 1 TB
Video - NVIDIA GeForce GT 640M (driver version 320.49) --2 GB RAM
RAM - 16 GB
Message 4 of 11
pmaloney5
in reply to: pmaloney5
This was a 2014 Activation Crash issue!! The above steps fixed it beautifully. After 4 days of searching and trying, I'm so relieved!
THANK YOU TravisNave!!!
Message 5 of 11
TravisNave
My pleasure!
Autodesk Forums:
Message 6 of 11
up662338
in reply to: TravisNave
Hello, I to am having the same issue as you:MaxIssue.png
The link that has been posted I cannot seem to find - it just sends me to another search database. Any help would be much appreciated - many thanks - Matt.
Message 7 of 11
pmaloney5
It appears the link for the fix is broken. These are the steps I used and everything worked fine.
http://knowledge.autodesk.com/support/robot-structural-analysis-products/troubleshooting/caas/sfdcar...
Hope that helps, Good Luck!
Message 8 of 11
sonnenkind1
I'm getting the same issue.  I've tried the fix above, with no luck.  My video card is an AMD Radeon R9 280.
Message 9 of 11
Tags (1)
Message 10 of 11
trishareilly06
hey,
i have windows 8
i had installed the autodesk products a while back... and now my 3ds max isnt opening and this is the error i keep getting... i tried to repair it as well but it did not work.... Maya works fine... only 3DS max is giving me this kind of error.... plz help!
Message 11 of 11
it was working when i was using windows 8. now on windows 10 it doesnt work
Administrator Productivity
