Installation & Licensing
New Member
npwilliams09
Message 1 of 5 (1,650 Views)
3ds max 2014 crashes on startup on Windows 8
1650 Views, 4 Replies
06-28-2013 05:16 PM
My 3ds max crashes on startup. I have tried installing the 2012,2013 and 2014 versions and they all crash on startup. Except for the 2012 one which runs for a minute then crashes. It works on all my other computers (which run windows7). Is the problem windows 8?
My specs are as follows
i7 3770k
gtx 650 ti
windows 8 pro
Need help asap
TravisNave
Message 2 of 5 (1,600 Views)
Re: 3ds max 2014 crashes on startup on Windows 8
07-02-2013 09:05 AM in reply to: npwilliams09
The problem is likely video card driver.  Make sure you are running a WHQL certified driver.
New Member
npwilliams09
Message 3 of 5 (1,580 Views)
07-03-2013 03:56 AM in reply to: TravisNave
I have updated my driver to the latest WHQL certified driver and it still
does not work
Member
pmaloney5
Message 4 of 5 (1,035 Views)
08-16-2013 08:43 AM in reply to: npwilliams09
I am experiencing this exact same issue with Win8 Pro trying to get 3ds max 2014 to install. It installed fine on win7.
New Member
jonmeldrum
Message 5 of 5 (922 Views)
08-22-2013 06:54 AM in reply to: pmaloney5
I am also having the exact same problem on my ASUS laptop running W7.
Max runs fine on my desktop PC with W7.
Ive tried all the possible fixes I could find. Max used to work on the exact same laptop.
