Installation & Licensing
3DS Max 2013 setup problem
1 REPLY 1
arican.burak
344 Views, 1 Reply
2013/2/5:12:47:44 burak BURAK-PC === Setup started on BURAK-PC by burak ===
2013/2/5:12:47:44 burak BURAK-PC Launch
2013/2/5:12:47:45 burak BURAK-PC PageOpen LaunchDialog
2013/2/5:12:47:45 burak BURAK-PC PageOpen LicenseDialog
2013/2/5:12:47:47 burak BURAK-PC PageOpen ProductInfoDialog
2013/2/5:12:48:12 burak BURAK-PC PageOpen ProductSelectionDialog2
2013/2/5:12:48:15 burak BURAK-PC PageOpen FullProgressDialog
2013/2/5:12:48:15 burak BURAK-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x86): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x86\VCRedist\2010SP1\vcredist_x86.exe /q /norestart
2013/2/5:12:48:21 burak BURAK-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x86) Succeeded
2013/2/5:12:48:21 burak BURAK-PC Installing Microsoft Visual C++ 2010 SP1 Redistributable (x64): C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\x64\VCRedist\2010SP1\vcredist_x64.exe /q /norestart
2013/2/5:12:48:27 burak BURAK-PC Install Microsoft Visual C++ 2010 SP1 Redistributable (x64) Succeeded
2013/2/5:12:48:27 burak BURAK-PC Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\Autodesk_3ds_Max_2013_EFGKJS_Win_64bit\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x64.exe /q /norestart
2013/2/5:12:48:40 burak BURAK-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
2013/2/5:12:48:40 burak BURAK-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x64) Failed Installation aborted, Result=1619
2013/2/5:12:48:40 burak BURAK-PC Rollback Microsoft Visual C++ 2010 SP1 Redistributable (x86) Failed Installation aborted, Result=1619
what should i do?
1 REPLY 1
DarrenP
in reply to: arican.burak
try looking through here: http://usa.autodesk.com/adsk/servlet/u/gsearch/results?siteID=123112&catID=123155&id=2088334&qt=erro...
and here: http://forums.autodesk.com/t5/Installation-Licensing/Error-1603-and-1619-installing-Revit-Architectu...
DarrenP
Administrator Productivity
