I have some problem with installation, and i can't solve it by myself.
This is the issue - I started to install http://img707.imageshack.us/img707/6905/installation1.jpg and after few seconds it shows this http://img688.imageshack.us/img688/7938/installation2.jpg
I even have nothing to clutch to fix it - none error msg or anything like that :<
Of course I tried to run Setup.exe file as administrator - without any changes.
Please feel free to ask for everything which can help You solve the problem.
Thanks in advance.
Pawel
the error is still 1603 but its still saying something about net framework
2013/4/10:17:47:57 Hi HI-PC === Setup started on HI-PC by Hi ===
2013/4/10:17:47:57 Hi HI-PC Launch
2013/4/10:17:47:58 Hi HI-PC Download Skipped SETUP_CONFIG http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/4/10:17:47:58 Hi HI-PC PageOpen LaunchDialog
2013/4/10:17:48:47 Hi HI-PC PageOpen LicenseDialog
2013/4/10:17:48:54 Hi HI-PC PageOpen ProductInfoDialog
2013/4/10:17:48:54 Hi HI-PC PageOpen ProductSelectionDialog2
2013/4/10:17:48:59 Hi HI-PC PageOpen FullProgressDialog
2013/4/10:17:48:59 Hi HI-PC Download Skipped DOTNET4 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/4/10:17:48:59 Hi HI-PC Installing .NET Framework Runtime 4.0: C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\NET\4\wcu\dotNetFramework\dotNetFx40_Full_x86_x64.exe /q
2013/4/10:17:49:49 Hi HI-PC Install .NET Framework Runtime 4.0 Failed Failure is ignored, Result=1603
2013/4/10:17:49:49 Hi HI-PC Download Skipped DOTNET4KB2468871 http://studentsdownload.autodesk.com/SWDLDDLM/2013/3DSMAX/WI/{5AE85775-089E-4B13-890D-83D19EC7E840}/...
2013/4/10:17:49:49 Hi HI-PC Installing .NET Framework Runtime 4.0 KB2468871: C:\Autodesk\WI\Autodesk 3ds Max 2013\3rdParty\NET\4\wcu\dotNetFramework\NDP40-KB2468871-v2-x86.exe /q /norestart
2013/4/10:17:50:05 Hi HI-PC Install .NET Framework Runtime 4.0 KB2468871 Failed Installation aborted, Result=1603
ive got to go right now ill try this tomorrow. ill get to you later! thanks for the help!
I tried a new user and it didnt work... was the new user supposed to have everything uninstalled? because it didnt.
