Installation & Licensing
Valued Contributor rob
Valued Contributor
1 Kudo
Post 1 of 3
Accepted Solution
3ds Max 2013 fails to install after clean and complete removal.
945 Views, 2 Replies
06-11-2012 02:07 PM
After removing all my autodesk products using the instructions in the service and support section, I can not reinstall 3dstudio Max.  The reinstall of Architecture was successful and the database that was corrupted has been restored.
So now I need help with understanding why I can get Studio to install.  Below is the log that was created during the install attempt.  I noted in the log where it failed in both "Normal" and "Safe" modes.  Please help me to figure out what I need to do to get this thing installed.  Thanks.
2012/6/11:14:54:09    rjole    ARCHITECTURE6    PageOpen    InstallCompleteDialog
2012/6/11:14:56:19    rjole    ARCHITECTURE6    === Setup ended ===
NORMAL MODE
2012/6/11:15:05:27    rjole    ARCHITECTURE6    === Setup started on ARCHITECTURE6 by rjole ===
2012/6/11:15:05:27    rjole    ARCHITECTURE6    Launch
2012/6/11:15:05:27    rjole    ARCHITECTURE6    [Error: 1052] The requested control is not valid for this service.
2012/6/11:15:05:45    rjole    ARCHITECTURE6    PageOpen    LaunchDialog
2012/6/11:15:05:52    rjole    ARCHITECTURE6    PageOpen    LicenseDialog
2012/6/11:15:05:57    rjole    ARCHITECTURE6    PageOpen    ProductInfoDialog
2012/6/11:15:06:30    rjole    ARCHITECTURE6    PageOpen    ProductSelectionDialog2
2012/6/11:15:12:51    rjole    ARCHITECTURE6    PageOpen    FullProgressDialog
2012/6/11:15:12:52    rjole    ARCHITECTURE6    Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/11:15:16:07    rjole    ARCHITECTURE6    Install    DirectX® Runtime    Succeeded
2012/6/11:15:16:08    rjole    ARCHITECTURE6    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\rjole\AppData\Local\Temp\_AI68DF.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/11:15:35:23    rjole    ARCHITECTURE6    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1602
2012/6/11:15:35:23    rjole    ARCHITECTURE6    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2012/6/11:15:35:26    rjole    ARCHITECTURE6    PageOpen    InstallCompleteDialog
2012/6/11:15:35:30    rjole    ARCHITECTURE6    === Setup ended ===
SAFE MODE
2012/6/11:15:39:45    rjole    ARCHITECTURE6    === Setup started on ARCHITECTURE6 by rjole ===
2012/6/11:15:39:45    rjole    ARCHITECTURE6    Launch
2012/6/11:15:40:01    rjole    ARCHITECTURE6    PageOpen    LaunchDialog
2012/6/11:15:40:03    rjole    ARCHITECTURE6    PageOpen    LicenseDialog
2012/6/11:15:40:06    rjole    ARCHITECTURE6    PageOpen    ProductInfoDialog
2012/6/11:15:40:40    rjole    ARCHITECTURE6    PageOpen    ProductSelectionDialog2
2012/6/11:15:42:28    rjole    ARCHITECTURE6    PageOpen    FullProgressDialog
2012/6/11:15:42:28    rjole    ARCHITECTURE6    Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/11:15:44:57    rjole    ARCHITECTURE6    Install    DirectX® Runtime    Succeeded
2012/6/11:15:44:58    rjole    ARCHITECTURE6    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\rjole\AppData\Local\Temp\_AIB412.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/11:15:44:58    rjole    ARCHITECTURE6    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1601
2012/6/11:15:44:58    rjole    ARCHITECTURE6    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1601
[Solved]
It turns out that it takes a full 48 minutes to re-install the software.
I just needed to update my patience to the latest version.
Valued Contributor
1 Kudo
Post 2 of 3
SOLVED: 3ds Max 2013 fails to install after clean and complete removal.
06-12-2012 06:58 AM in reply to: rob
[Solved]
New Member
0 Kudos
Post 3 of 3
Re: SOLVED: 3ds Max 2013 fails to install after clean and complete removal.
04-14-2013 01:35 AM in reply to: rob
I'm having the exact same problem, reinstall failure in exactly the same place.
You say you had to be patient, but how did that get you around the pop-up error where it complains about a bad registry key?
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
