Installation & Licensing
3ds Max 2013 fails to install after clean and complete removal.
2 REPLIES 2
Rob_J_
1237 Views, 2 Replies
After removing all my autodesk products using the instructions in the service and support section, I can not reinstall 3dstudio Max.  The reinstall of Architecture was successful and the database that was corrupted has been restored.
So now I need help with understanding why I can get Studio to install.  Below is the log that was created during the install attempt.  I noted in the log where it failed in both "Normal" and "Safe" modes.  Please help me to figure out what I need to do to get this thing installed.  Thanks.
2012/6/11:14:54:09    rjole    ARCHITECTURE6    PageOpen    InstallCompleteDialog
2012/6/11:14:56:19    rjole    ARCHITECTURE6    === Setup ended ===
NORMAL MODE
2012/6/11:15:05:27    rjole    ARCHITECTURE6    === Setup started on ARCHITECTURE6 by rjole ===
2012/6/11:15:05:27    rjole    ARCHITECTURE6    Launch
2012/6/11:15:05:27    rjole    ARCHITECTURE6    [Error: 1052] The requested control is not valid for this service.
2012/6/11:15:05:45    rjole    ARCHITECTURE6    PageOpen    LaunchDialog
2012/6/11:15:05:52    rjole    ARCHITECTURE6    PageOpen    LicenseDialog
2012/6/11:15:05:57    rjole    ARCHITECTURE6    PageOpen    ProductInfoDialog
2012/6/11:15:06:30    rjole    ARCHITECTURE6    PageOpen    ProductSelectionDialog2
2012/6/11:15:12:51    rjole    ARCHITECTURE6    PageOpen    FullProgressDialog
2012/6/11:15:12:52    rjole    ARCHITECTURE6    Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/11:15:16:07    rjole    ARCHITECTURE6    Install    DirectX® Runtime    Succeeded
2012/6/11:15:16:08    rjole    ARCHITECTURE6    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\rjole\AppData\Local\Temp\_AI68DF.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/11:15:35:23    rjole    ARCHITECTURE6    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1602
2012/6/11:15:35:23    rjole    ARCHITECTURE6    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1619
2012/6/11:15:35:26    rjole    ARCHITECTURE6    PageOpen    InstallCompleteDialog
2012/6/11:15:35:30    rjole    ARCHITECTURE6    === Setup ended ===
SAFE MODE
2012/6/11:15:39:45    rjole    ARCHITECTURE6    === Setup started on ARCHITECTURE6 by rjole ===
2012/6/11:15:39:45    rjole    ARCHITECTURE6    Launch
2012/6/11:15:40:01    rjole    ARCHITECTURE6    PageOpen    LaunchDialog
2012/6/11:15:40:03    rjole    ARCHITECTURE6    PageOpen    LicenseDialog
2012/6/11:15:40:06    rjole    ARCHITECTURE6    PageOpen    ProductInfoDialog
2012/6/11:15:40:40    rjole    ARCHITECTURE6    PageOpen    ProductSelectionDialog2
2012/6/11:15:42:28    rjole    ARCHITECTURE6    PageOpen    FullProgressDialog
2012/6/11:15:42:28    rjole    ARCHITECTURE6    Installing DirectX® Runtime: E:\3rdParty\DirectX\DXSETUP.exe /silent
2012/6/11:15:44:57    rjole    ARCHITECTURE6    Install    DirectX® Runtime    Succeeded
2012/6/11:15:44:58    rjole    ARCHITECTURE6    Installing Autodesk® 3ds Max 2013:  TRANSFORMS="C:\Users\rjole\AppData\Local\Temp\_AIB412.tmp\x64\max\3dsMax2013-standalone.mst" ADSK_EULA_STATUS=#1 MUILANG=en-us ADSK_SOURCE_ROOT="E:\" INSTALLDIR="C:\Program Files\Autodesk\3ds Max 2013\" FILESINUSETEXT="" REBOOT=ReallySuppress ADSK_SETUP_EXE=1
2012/6/11:15:44:58    rjole    ARCHITECTURE6    Install    Autodesk® 3ds Max 2013    Failed    Installation aborted, Result=1601
2012/6/11:15:44:58    rjole    ARCHITECTURE6    Rollback    DirectX® Runtime    Failed    Failure is ignored, Result=1601
2 REPLIES 2
Rob_J_
in reply to: Rob_J_
[Solved]
It turns out that it takes a full 48 minutes to re-install the software.
I just needed to update my patience to the latest version.
ronaldTarrant
in reply to: Rob_J_
I'm having the exact same problem, reinstall failure in exactly the same place.
You say you had to be patient, but how did that get you around the pop-up error where it complains about a bad registry key?
Administrator Productivity
