Installation & Licensing
3DS Max 2012 wont accept product key
2 REPLIES 2
FlameTop
7163 Views, 2 Replies
Hello, I have downloaded my subscription upgrade from 3DS Max 2011 to 2012. During installation it asked for my serial number and product key. It accepts my 2011 serial number fine, but states the product key is invalid. Just in case it was the installer I selected the trial option and finished the installation. However, on startup of 2012 if I try to authorize the copy there it states the same thing; the serial is accepted but not the product key. I have searched all over the subscription site but cannot any way to obtain a new product key? thanks Phil Camp
2 REPLIES 2
TravisNave
in reply to: FlameTop
To activate your product, you will need to use your 2012 serial number instead of your 2011 serial number.  You can find this information on your Subscription site.  Your product key is not unique and will be the same for all Max 2012 products.  It should likley be the same as your 2011 except with a D instead of a C, unless your product suite has changed.  However, unless you use your 2012 serial number you will not be able to activate.
Your information is on the Subscription site.  If you cannot find it, you may want to contact Autodesk Subscription services or your reseller.
Autodesk Forums:
FlameTop
in reply to: TravisNave
Thank you for your help. I double checked and still could not find a new serial or key on the subscription site. So I contacted my reseller and they have provided the new serial and key. Thanks again. Phil
Administrator Productivity
